Another cam spec'ing post!
Old 02-22-2012, 12:49 PM
FRiCK's Avatar
Default Another cam spec'ing post!
So Pat spec'd out a cam for my C5Z and things have slightly changed since then. I now posess livernois stage 3 243's 62cc chambers, no more nitrous and I want it to have a manly idle lol I want this thing to sound mean! I still want to retain the same power band of the current cam. Rev limiter set at 6800-6900... And it needs to be drive able down low and stay punchy in the mid range...
https://ls1tech.com/forums/generatio...cd-my-z06.html
Old 02-22-2012, 12:57 PM
Old School Heavy
speedtigger's Avatar
You could tighten up the LSA to make it idle harder. But the size of the cam still fits your desired RPM range.
Old 02-22-2012, 01:53 PM
99Bluz28's Avatar
Your current cam should still work really good, but I'd have to agree with just going with a tighter LSA (111 or 110), and maybe even dropping down to a 230 on the exhaust lobes.
Old 02-22-2012, 01:59 PM
FRiCK's Avatar
I agree with all of that. Just wanting opinions on the LSA and the exhaust side. Intake is staying at 230
Was kinda trying to get out of another $25 spec'ing fee is all lol
Old 02-22-2012, 03:19 PM
FRiCK's Avatar
So would I want a 111+2 then?
Old 02-22-2012, 04:02 PM
Old School Heavy
I am sure that will work. Or, even 111+1. Run it by Patrick. I bet he will discuss it with you at no extra charge.
Old 02-22-2012, 04:42 PM
Killer5.3's Avatar
If it was me I would use the same cam. I doubt he will make much change in the specs , may 112 LSA. I bet there isn't much if any difference on exhaust flow between the 2 heads. Probably intake flow and higher in the lift range than your cam will be. Like th eother guy said, he may adjust them for you at no charge. I would at least contact him and see.
Old 02-22-2012, 05:26 PM
FRiCK's Avatar
I guess all I'm wanting is a max effort 230 cam that idles hard. I dont want to leave anything on the table by going with a street friendly LSA...
Old 02-22-2012, 06:16 PM
spicebird98's Avatar
i'd get the same cam on a 111+2 or so. i'd like to see the results of a 231/238 111+3 though LSL/LXL because i plan to change to that cam within the next couple months
Old 02-23-2012, 07:02 AM
LS1 Tech Administrator
Patrick G's Avatar
I would tighten the LSA and exhaust if you're not going to run nitrous. I'd run that 230 EPS lobe on the intake with a 111LSA on a 109 intake centerline. For the exhaust, I'd run a 230 LXL lobe if you wanted better power and street manners in the 1500-3500 rpm range or a 234 lobe if you valued power above 6500 rpm more. For what it's worth, the 230/230 111LSA cam has the same 8 degrees of overlap as the 230/238 113LSA cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
