Head bolt removal?
I dont think they break very often. I had no problems pulling my stock bolts. I would go with studs with your new heads. I feel that studs are far superior to bolts. Much easier on the threads and also you dont have to worry about cracking your block if you have a little coolant left in your block.
I've noticed that the head bolts are like any other bolts...if you crank on the same one it will be more likely to break...that's why I like to "reverse torque" the headbolts by loosening them in the reverse order of the headbolt order you use to put the heads on. I also do the loosening in a couple stages which puts less stress on the bolts and makes them less likely to break. I know people that just crank them off with a 1/2 inch impact in no particular order, but I like to be safe. I usually use a junk torque wrench for the initial cracking loose of each bolt, and then I use the 3/8 impact (less torque then the 1/2 in) and loosen them in 2 stages starting from the outside and working my way in. Some of my friends say it is not needed, but I can't afford to break a bolt and cause more $/work. Also the few engines I have worked on have been aluminum LS engine blocks, which in my eye makes it even more sketchy as far as breaking a head bolt and causing the need for the use of some unsavory methods lol. If it was an iron block I wouldn't be as concerned. Also another trick I like to use if I feel a bolt getting tight when loosening, I will tighten it back into the hole a Couple turns to hopefully "unbind" the bolt. Everybody does it a lil bit different, but I hoped I at least helped out a little. By sharing my experience.
There is a GM Tech Bulletin that says you have to first hit the bolt heads with a hammer/drift to "unfreeze/unjam" the threads before attempting to loosen the bolts.
