What cubic inch
No I was just thinking about doing it I have the block and can get a stroker crank for fairly cheap plus it would leave alot of meat left on the cylinders if it needed another rebuild
Sounds like a interesting little stroker. 360. Usually boost tends to match well with big bore small stroke, for the revs. I wouldn't put this on boost. Nitrous, or NA would be pretty stout. Not sure what this small bore/ long stroke setup would do power charactaristics wise. I'd throw it together with budget parts just to see what it's got.
Most of the time clearance isn't a problem with a 4" stroke but very close, but 4.125" needs more work...might just need a small spot at each side of the bottom of the cylinder walls botched to clear the big end of the rods.
Id like to see someone use a 4.8l crank in a 4"+ bore with crazy boost to see just what it could do/ rev to.
I can see this 360 cube engine making more torque than anything. would make a good engine for someone looking to up the towing power of a truck, but in an f-body or similar, probably wouldnt be as good of a performer as say a 408/402. I can see power and torque levels being on the same plane as a 383 LS1, but a reasonable amount less.
I understand the lack of cubic inches, and the fact it is undersquare is what makes is more efficient at lower RPM's, which in turn, combined with the right cam, will make for an off idle torque monster. I agree with that. However, I still beleive that an oversquare engine would be better suited to a FI build.
I'm not sure what bore to stroke ratio has to do with the design of the lifters and fuel it runs on...
A hydraulic roller engine can be built to run to higher rpm's as well as low...most of it is in the cam. You know this.
Larger bore, short(er) stroke engines generally respond to FI builds better than small bore large stroke engines.
Moderator
Pump gas hydraulic rollers are limited in RPM and octane, unlike most dedicated race cars that use solid rollers and race fuel. While a HR could turn "high rpm", it's still limited compared to solid roller combinations. Most HR setups that spin over 7500 RPM actually mimic a solid roller anyways.
So when you're limited in RPM, you're only going to be able to take in X amount of air naturally aspirated. With boost, it's not the RPM that limits the amount of air injested but the point at which the fuel/air mixture detonates. In either case, its very important to make the most out of the combustion which is where the undersquare combinations shine.
Larger bores are better suited to an engine that can run higher RPM and higher octane fuels.
