Ouch... Lifter eats my cam
Old 02-23-2012, 08:19 PM
zerogravity779's Avatar
Default Ouch... Lifter eats my cam
Had a lifter eat my cam. So..... I installed a TR CheaTR cam. Pretty happy with it so far. The cam that got ate was a TR 224. I also upgraded the lifters and lifter trays.
The specs below are from the Thunder Racing site:
99-TR-CHEATR v.3-CAM Thunder Racing Custom Camshaft
" CheaTR v.3" - 219/230 .607/.604 117 LSA. Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle in 5.7L or Larger. Minor tuning required on automatic transmission cars.
Mods:
- Thunder Racing CheaTR Cam
- LS6 intake
- Corvette Oil pump
- FLP full-length headers w/ 3" off-road pipes
- Dynomax Super Turbo Muffler
- TEA Stage 1.5 heads
- 3.73 gears
- Subframe connectors w/ welded in relocation brackets
- BMR AdjustableTorque Arm and Panhard Rod
- Rebuilt (stronger than stock) transmission
- Lowered 1.5 inches with Eibach pro kit and Edelbrock IAS Shocks
- Kenwood head unit with polk/momo speakers and pollk/momo 975 watt amp
Pics of the TR 224 cam, and the worn lifter
Last edited by zerogravity779; 02-24-2012 at 07:06 PM. Reason: Added New cam Specs, Current mods and PICS
Old 02-23-2012, 09:25 PM
ggino85's Avatar
63 views and not one comment.............
what caused the lifter to fail? age? high rpm? what are the specs on the cheater cam? what other mods do you have?
Old 02-24-2012, 10:02 AM
M6transam's Avatar
Pretty sure I have a lifter bad, I assume my cam is ruined . Luckily its a stock cam.
Old 02-24-2012, 11:35 AM
blackandgold's Avatar
Pics?
Old 02-24-2012, 04:05 PM
WarShrike's Avatar
You'd be amazed at how many of those hits on the thread are from searchbots like google spider...
Old 02-25-2012, 09:32 AM
What caused it ti fail...... my guess is the crap LS1 lifters in stalled on these cars. It did show some wear on it from other lifters, but the #3 intake lifter had a flat spot on it from it failing. It wasnt real "gritty" (thank god) but was gummd up a little. So she got LS7 lifters with LS2 trays. For now I have put a stock tune back on it, and it seams to do alright. Its only been a week so far, more to follow. Yester day I did bump the idle up to 850 rpm..... but today I will reflash it back to stock. I bumped it up because of the slight shake it had..... but I kninda liked it. With the headers and 3" pipes I have..... there is no "cheater" cam about it... you can tell it has one. Running the stock tune the rpm was in the mid 600 range. I went with this cam because I wanted a streetable cam that didnt need a stall. When I bought the car in December, the guy I got it from just had the tranny rebuilt, and put in a factory stall because he wasnt sure if he wanted to keep dumping more money in it before he sold it. With the factory stall, and the 224 cam, it realy wanted to push through the brakes at the lights. So instead of getting a cam kit (Cam, springs, push rods) for close to $800, and dumping money in a stall (close to a grand).... I just went with a milder cam. My other option was the "old man cam" from thunder racing. But when I called them the sales guy kept pointing towards this one.
Old 02-26-2012, 04:58 AM
CHADsterss's Avatar
Best thing to do is spend a extra $130 for Morel link bar lifters instead of the LS7 lifters and lifter trays.
Old 02-26-2012, 09:28 AM
LSX Mechanic
Damian's Avatar
It isn't always the lifters fault. Cam hardening can play a role in a camshaft failure as well.
Old 02-26-2012, 09:31 AM
SideStep's Avatar
EXACTLY! I had this happen to my F13 cam..
Old 02-27-2012, 06:05 PM
Hackscamaro's Avatar
i have seen to many of these some from cam hardening and some from lifter failures. i had a ls7 lifter lock up in my lt1 and take out my cam. i have seen a few cam hardening issues at work as well as a couple lifter issues. on all of the new vehicles gm claims its the cam not being hardened properly. i had one come out of a truck that the lobe was completely ate off and only a circle left
Old 02-29-2012, 06:37 PM
Mine was an intake lifter being stuck.... you can see it in the pic above.
Old 02-29-2012, 06:43 PM
sepsis's Avatar
I wonder what cores they use? Maybe Comp?
Old 02-29-2012, 07:02 PM
ep142's Avatar
that sucks, I know the feeling it just happened to my ms4......just have to build it stronger, hoefully the new lifters and trys keep it from happening again.
Old 02-29-2012, 07:04 PM
ep142's Avatar
did you say it was the #3 intake lobe? that is what wore on mine.
Old 02-29-2012, 07:07 PM
RsSean's Avatar
Funny I had two of those tr224 cam and did the same thing.
You loose oil pressure at all?
Old 02-29-2012, 07:39 PM
Yeah....but I was wrong, it was the #4 intake.
Anyone want a ate up TR 224 cam?? Pay its ride and its yours!! Dont know what good it is!!
Old 02-29-2012, 08:18 PM
Thule's Avatar
2 car here on the northpolw had this issue last summer
Old 02-29-2012, 08:45 PM
SladeX's Avatar
I had a TR224 cam do the same thing last year.
Quick Reply: Ouch... Lifter eats my cam
