317 head stock retainers with Z06 yellow springs?
Old 02-25-2012, 02:35 PM
w227's Avatar
Default 317 head stock retainers with Z06 yellow springs?
Will these retainers work? I ended up buying the 317 valve train, and just found some Yellow z06 springs I want to use..can you use the 317 stock retainers with ls6 valves?
Old 02-25-2012, 02:40 PM
JaYZeig's Avatar
this probably dont help much, but im running stock 317 hardware with pac1518's
have had no problems in nearly 1000 miles
Old 02-25-2012, 03:27 PM
w227's Avatar
I ask cause this hardwares going into a jeep 4.0 inline 6 I bought the 6.0 LQ4 stock hardware for 42 bucks. And then just saw the yellow Z06 springs for 12 + 12 for shipping lol. But from what I've read the Vette forums, the Z06 springs are drop in and go..at least what I read was that 1 guy broke a Z06 valve with a big cam (common issue for 02-03 I guess), and used a LQ4 valve as a temp replacement until he could get aftermarket valves.. Had pictures and all, so seems it'll work out!
I want Z06 valves, cause after some quick searching, I found out that LQ4 valves get valve float with a stock cam around 6krpm. A few times I read that. I'll be running a custom grind/remade Comp 239 .493/.512 lift cam at 106LSA. The regrind was for a 106Lsa and a built in 3* of retard because the cam is made for like 5800rpm, retarded it to get it down to around 5400rpmm, And lower Lsa cause I wanted some lope. Its like the 3rd biggest cam offered for us jeep guys so I wanted to be safe!
Heres the comp 239 idling away..mine should lope slightly more than this with the lower Lsa and slight retard..hoping to keep my 650rpm idle
http://www.youtube.com/watch?v=wEyD8sn-IaA
Not bad getting a full valve train that weighs less & is bigger/better than stock equipment for under 75 bucks huh?
Replacement jeep 1.91/1.50 valves are 11 bucks a piece, not stainless or anything, just replacements! SBC SS undercut/swirl polished valves can also be used & require less work to make them fit than LS1 stuff, but around 80 per side..or 160 for just valves & they will be heavier than stock jeep equipment, still need springs & such which is even more $$$.
So I hit ebay and found Lq4 valve train & now Z06 springs..they will weigh less than the Jeep or SBC stuff, are slightly bigger 2.00/1.55 and tuliped undersides so I can get my quench height tighter without bumping my compression ratio!
LSx stuff is deffinetly the best choice lol.
Quick Reply: 317 head stock retainers with Z06 yellow springs?
