LQ4 105k????
Old 02-27-2012, 01:52 PM
Camaro9969's Avatar
Default LQ4 105k????
Well here we go........Pulled the heads off the 105k 2004 denali lq4 and this looks like ****. and that oil in there is tranny fluid WTF??? Why? It has a 90 day warranty so i'll just bring it back and get another if this is shot. It spins freely no problem at all. But this looks like hell to me anyways....
Old 02-27-2012, 02:23 PM
ScottyBG's Avatar
Did it have an intake manifold on it when you got it? I'd think possibly someone sat a torque convertor on top of it and some fluid ran down in the intake port on the head. From the pictures, that looks about how I would expect for a 105k mile pull out? The carbon is normal, clean it out with a rag with brake parts cleaner on it, so you can see the condition of the cylinder wall. I don't see any rust in the photos, or anything else abnormal? I've only pulled a few of these apart in my life and not really an expert, but yours looks similar to what I have seen, except for the trans fluid. Have a local shop take a look at it if your in doubt? I think what you have, may be a diamond in the rough, that carbon can make things look bad.
Old 02-27-2012, 02:35 PM
Camaro9969's Avatar
well thats a good thing to hear. I pulled my ls1 apart and it looked amazing compared to this. The intake actually was on top of the motor it was complete when i took it from the yard. I just was a little worried when i looked at it how nasty it was. Im new when it comes to all this and just seeing this compared to my other motor shocked me. And the transmission fluid is so weird i will call and ask why that was in two of the cylinders. Thanks for clearing it up with me haha
Old 02-27-2012, 02:45 PM
mark21742's Avatar
I've seen people drain the oil out of w motor that is going to sit and put tranny fluid in it...even fill it all the way to the top of the valvecovers....high detergent and prevents rust? Not sure hoe it would work on rubber/plastic parts though
Take the rear cover off and pull the barbell out....see if it has any hunk built up on it.
Believe it or not I've seen engines with a lot more buildup than yours that once cleaned up turned out to be really nice
Old 02-27-2012, 02:59 PM
Camaro9969's Avatar
oh and the guy at the yard told me the transmission fluid is from them. He said they use trans fluid to lubricate it when its sitting haha i said why wouldnt you use just motor oil...but well thats strange but at least i know.
Old 02-27-2012, 03:03 PM
Camaro9969's Avatar
i didnt notice you posted this haha so i guess he wasnt lying about it. This is why this site is awesome thanks! wheres the barbell? just take off the flywheel and cover its in there?
Old 02-29-2012, 06:48 PM
Camaro9969's Avatar
After
Old 02-29-2012, 07:00 PM
Matt0matic's Avatar
What'd you use to to clean it all up? Looks great. Going to rebuild, or run as is?
Old 02-29-2012, 07:15 PM
mark21742's Avatar
Told you it would clean right up
Old 02-29-2012, 07:28 PM
Camaro9969's Avatar
Ya man you were right i didnt think it would even come close to this clean haha i used engine degreaser and some wire brushes but was careful and let it soak a while..
Thanks you i'm not going to rebuild it i'm just going to do the upper. Cam, springs, pushrods, and do arp rod bolts and head bolts.
Old 03-02-2012, 08:02 AM
JustinCody's Avatar
I don't mean to jack the thread, but my lq4 looked just like that. I got it cleaned up and one cylinder has one little discoloration place in the wall. About an inch long. You can't feel anything, only see it. Everything else is perfect. Should that be anything to worry about?
Old 03-02-2012, 08:06 AM
Rare96LT1Formula's Avatar
That LQ4 cleaned up VERY nicely. Also suprised to hear about the trans fluid, never heard that one before..
Old 03-02-2012, 08:11 AM
mark21742's Avatar
Can you post up a pic of it?
Old 03-02-2012, 08:56 AM
JustinCody's Avatar
About the best I could get on my way out the door this morning. It set up for a few months, rotating assemply spins great. I cleaned some debris out from the clean up and soaked the cylinders in WD40 to prevent rusting while waiting on parts. WD40 emptied out of this cylinder in about 8 hours with it about half full. It's not scored or anything. Smooth to the touch.
Old 03-02-2012, 10:21 AM
Ph.D. in HUBRIS
custm2500's Avatar
Looks good.
Are you sure that isn't a LQ9. In a denali it should be a LQ9 not a 4.
Old 03-02-2012, 12:06 PM
ZeeTwentyFate's Avatar
its nto flat tops, its a LQ4, LQ9 has flats.
Old 03-02-2012, 12:46 PM
mark21742's Avatar
From here it looks more like stains in the cylinder....if you feel the need you could drop the crank and pistons and run a hone down through it real quick, but I don't think you need to
Old 03-02-2012, 04:00 PM
JustinCody's Avatar
That's exactly what it looks like, I just didn't know what would have caused it.
Old 03-02-2012, 04:31 PM
Camaro9969's Avatar
Thanks man ya i agree i dont get the tranny fluid thing and he was such a wise *** when i called him about it
Old 03-02-2012, 04:33 PM
Camaro9969's Avatar
Originally Posted by custm2500
Looks good.
I hear that but i looked up the engine code and its a lq4.........ive heard only the escalades came with lq9's and some of the special edition trucks
Quick Reply: LQ4 105k????
