father and son budget build need help!
Hello I'm an older car guy and a newbie to ls engines ! I have a lq4 that I picked up Friday and its in bad shape! Had a blown head Gasket ( I thought) but found a spot on the heads were a 1/4 inch of material was missing ! Anyways I'm not gonna fix them! Here's my question. A friend gave me some 853 heads with beehive springs fresh 5 angle valve job ...but they have been milled 30 thousandths . I think that puts them around 62cc. Not sure! He gave me a 228/228 comp cams. Can I use this heads without any ptv clearance issues? I don't have the extra money for 799 or 243 heads and I've done searches so any help at all would be appreciated!
Thanx guys! I hope to figure out how to post my buildup on here soon and put some pics up! And my son is 12 and it has been awesome teaching him the stuff I've learned and learning new stuff together!
Id love it if you could post a pic, I've heard of the notch, but never seen it
when you get your composite gasket
might as well size the crush thickness for a better quench
definitly mock it up with some clay
do a search for the optimal quench
i believe .035 to.041
running those 853 with an lq4 is going to bring
your compression up quite a bit i would think
and a tighter quench will help
.030 is pushing it for piston to head clearance when everything is hot and spinning fast, but gives a lot of detonation reduction and let's you get closer to the edge of max power vs reliability.
Well I can't figure out how to post pics yet off my phone. But I just checked my heads and they do have it! So thanx bww3588! Mark21742 I searched (853 heads notch pics) and it pulled up a thread called something ( I think) " quick q about arp studs and head gaskets). They had 2 good pics !
Thanx again guys for all your help! But I have another question. Which head Gasket do I use? Will the fel pro 9199pt work ? Or do I need to get ls1 gaskets that have a right and a left?
Well the guy who sold me the 6.0 felt bad and hooked me up with a aluminum 5.3 and it has 799 heads on it so I'm taking the springs and everything else off the 853 heads and putting them on those! Thanx again everybody !
