Will valve covers from a 5.3 work on ls1s?
Old 03-03-2012, 09:31 PM
Mr. Trick's Avatar
Default Will valve covers from a 5.3 work on ls1s?
Not sure if this is in the right place, but I just want to double check and make sure they will fit the coil brackets for a ls1 f-body.
Old 03-03-2012, 09:41 PM
Lee12609's Avatar
if not use the truck brackets. so long as they are centerbolt if yours is a 99+ ls1 they will bolt on, do a cross on the coil brackets on GMpartsdirect or some other OEM parts retailer to see if the part numbers are the same.
Old 03-03-2012, 10:22 PM
wildcamaro's Avatar
Yea the will work I used 5.3 valve covers on my 98 ls1 with 243 heads...Not 100% sure on the PCv setup though...
Old 03-04-2012, 06:22 PM
Mr. Trick's Avatar
Cool thanks. Do they need different coil brackets or were you able to use ls1s coil brackets? I'm also putting 243s on my 98. Also can the stock center bolt valve covers clear jesel rockers without spacers?
Old 03-04-2012, 06:50 PM
Steve01SS's Avatar
Yes I have 5.3 covers on the ls1 motor in my corvette. The stock ls1 coils fit just fine. The only thing that might be different is the number of PCV hoses on the covers. Depends on the covers. You should be able to make the hose config work. No idea on the Jesels.
Old 03-04-2012, 08:22 PM
wildcamaro's Avatar
I'm pretty sure you need valve cover spacers for the jesels...and you need a coil bracket bc on 98s the coils bolted directly to valve cover...you can get the brackets cheap used though
Old 03-04-2012, 09:16 PM
1 nasty z's Avatar
a 2000 4.8 will use the same valve cover and brackets as well right?
Old 03-04-2012, 09:31 PM
Deviant LS1's Avatar
If they're center bolt valve covers they'll go onto ls1 center bolt heads. Your LS1 coil rails will bolt onto the valve covers. The only difference is the PCV hook ups.
Old 03-05-2012, 04:20 PM
Mr. Trick's Avatar
Yeah I need to get coil brackets I just wanted to make sure coil brackets from a car will bolt up to truck valve covers, cause I think truck coils are different.
Quick Reply: Will valve covers from a 5.3 work on ls1s?
