Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
- Camaro and Firbird LS Engine Head Cylinder Guide and General Information<br>Important information to help you understand your Camaro or Firebird.
cylinder head bolts, which is best?
im doing a head swap on my ls1 98 camaro while the engine is still inside the car, I want to know which head bolts are best in this situation. should stick with the stock head bolts and just get new ones of those, or upgrade to ARP head bolts? i would prefer head studs but i dont know if they would allow e to swap the heads with the motor in the car.
head studs/bolts
i'll catch hell for suggesting it but the ebay studs ($80) are swedged with allen heads, i believe you could swap the heads in the car, hang the heads on the small upper studs, roll the longers in with an allen, then add the nuts and torque.........just take your time to make sure the studs are lubed good on both ends so that they do not bind going in.....
they are refering to bolts, sorry but i'll take the ebay studs over the bolts anyday. the only issue i've seen on anyones results with the ebay stud kit is the guy who tried to torque the studs into the block using the allen head to 50 lbs. (he's an idiot). know of 4 sets local one of them being mine that work just fine and had zero fitment or performance problems.......arp is overpriced, sorry but facts are facts, the ebay studs work.
To the OP You can remove the heads with the engine in car if You have studs ,,,,,just remove the nuts , then remove the studs and then the heads . To re-install just put the heads on top of the gaskets on the locating roll pins then install the studs by hand and make sure they're in as far as they're supposed to be , then washers n nuts or just nuts whichever and torque .
If your looking for the best like the title suggest ARP would be the choice. However has anyone ever had any issues with thes ebay studs? they seem to be a nice alternative and all i see is everyone recommend arp with no reason why other than a name.
I'd like to know if the ebay ones have ever broke, failed some way, or stretched????
I guess it all depends on how much money you have invested in your engine.
For my project, a $200 difference (ARP vs ebay studs) is a drop in the bucket, by comparison. I have never heard of an ebay stud failure, but I will be going with ARP.
