Budget LQ4 with 243 Heads...NOW WITH DYNO RESULTS!
Old 03-07-2012, 10:54 PM
LS1 Racing's Avatar
Default Budget LQ4 with 243 Heads...NOW WITH DYNO RESULTS!
I picked up a nice LQ4 with 80k miles to go in my 6-speed Z28. I'm not going to do a complete rebuild, as both oil pressure and compression are both good.
I'll be putting on some 243 heads that are being cleaned up by West Coast Cylinder Head...Basic resurface, valve job and some new guides but no CNC, as I'm on a budget. I'm also installing new lifters and an LS6 oil pump, but now I have to figure out what I'm going to do for a cam. I'm looking for something that will be more potent than the 359 RWHP I get from my LS1 (see sig for mods), but I don't want to totally destroy my highway gas mileage, nor do I want to replace springs every 20,000 miles. I'd like to get over the 400 RWHP barrier while still meeting the above requirements.
Any suggestions for a cam that will do this?
The following users liked this post:
Homer_Simpson (12-25-2021)
Old 03-08-2012, 11:25 AM
dodson55's Avatar
i have a tsp 233/239 in my lq4 with 243 heads times are in my sig car has more in it with a better 60ft lol and car drives great and gets 25mpg highway and 16mpg in town and sounds good
Old 03-08-2012, 12:18 PM
mark21742's Avatar
Dodson probably has the cam you want, or something close to it...whatever cam you go with keep your lift under .600", the ramp rates will make your springs last longer.
Plus you can go a little longer duration with your bigger cubes and still have very good street manners.
Old 03-08-2012, 12:46 PM
DarkFox118's Avatar
subscribe to see what you wind up with.
I'm running a rebuilt LQ4, ls6 oil pump, ls6 intake, tsp stg 2.5 ls6 heads, and a tsp 228r (228/228 .588", 112lsa)
it's not in yet, but I'm hoping to be near or over 400whp with it. I'm dropping it off tomorrow to have it finished up a bit. Gonna be a while before it goes in tho.
Old 03-08-2012, 12:54 PM
LS1 Racing's Avatar
And the TSP cam mentioned by Dodson doesn't have super-aggressive ramp rates? I know there's power to be had there, but I'd rather leave it on the table than have to worry about broken springs!
Old 03-08-2012, 12:55 PM
LS1 Racing's Avatar
Let us know what you think when it's in!
Old 03-08-2012, 12:58 PM
DarkFox118's Avatar
Will do! It's behind an A4 tho, and to a 2.73 rear so my results will vary to yours, you already have a better setup than I do to drop into.
I'm debating if I should wait on an 80e swap or just run my 60e, that and some misc. odds and ends (you know.. couple grand of odds and ends ) are all that's holding it up.
I had the heads milled .030. I'm shooting for ~11:1 compression on this motor.
Old 03-08-2012, 01:05 PM
dodson55's Avatar
run the 60 til she blows lol but you do need a gear change
Old 03-08-2012, 01:07 PM
MASS seller approved
low2001gmc's Avatar
lq4, ported unmilled 243s, fast 102 w/ fast 90tb, bolt ons, 3400 stall, 4.11s.....
comp 228-230, 588-592, 111.......3000 up rpm power band.......in a truck
0352Marine (10-07-2019)
Old 03-08-2012, 01:10 PM
mark21742's Avatar
Id look at gears, that could help your 60 last longer too
Old 03-08-2012, 05:16 PM
Turd Gen Guy
1nasty86's Avatar
Vrx5 or tr230/236 and rock out
BigDZ28 (06-07-2021)
Old 03-08-2012, 07:29 PM
Kooljames20's Avatar
subscribed I'm working on my lq4 too and not sure what route to go!!
Old 03-08-2012, 07:38 PM
Stoney667's Avatar
I went with the EPS 234/246. Should be finished in a few weeks.
LQ4, 234's, LS6 Intake.
Old 03-08-2012, 10:52 PM
richard david's Avatar
I have the lq4 with untouched 243s and the eps234-246 also but with victor Jr. 10.98@123 so I guess it works
Old 03-08-2012, 11:02 PM
badazz81z28's Avatar
Why 243s? With a 4" bore I would try and get the LY6/LS3 heads...
Old 03-08-2012, 11:23 PM
LS1 Racing's Avatar
Because I'm on a budget and I already had the 243s.
PGE_Von (08-01-2019)
Old 03-09-2012, 01:53 AM
01cherryreds10's Avatar
Stage 2.5 PRC 243's and a TR224 made 378rwhp with a stock LS6 intake on my car. Swapping the cam out right now for a 231/234 EPS spec'd by Pat G.
Old 03-09-2012, 04:55 PM
DarkFox118's Avatar
did you have any mill work done on the heads? What compression were you pulling on this?
224s a pretty mild cam for the 6.0s, good numbers none the less tho.
Would love to hear what you hit with the new cam.
Old 03-09-2012, 11:10 PM
garygnu's Avatar
Pat-G will spec you a cam that will meet all your goals .with the extra cubes it can be mild.
Old 03-10-2012, 07:49 PM
-Q-
-Q-'s Avatar
I had a LQ4 shortblock with TSP Stage 2.5 LS6 heads and LS6 intake in my old WS6. Pat G spec'd me a cam for it....238/242, .604/.605 lift on a 112+4. Very streetable, and rolled out. No dyno #s or track times, though...
Here's a clip. Cutout opens around 35 seconds in...
Quick Reply: Budget LQ4 with 243 Heads...NOW WITH DYNO RESULTS!
