LS1 to LQ4 help
LS1 to LQ4 help
Ok I plan on going from ls1 to an lq4, hopefully a 408 and planning on boosting through a d1sc procharger. Are any of the parts interchangeable from the ls1 to the lq4 such as ac compressor or any accessories? Also what heads should I go with on the lq4 block seeing as how I dont want the truck intake?
thanks man, i was just making sure because im in afghanistan and i wanted to know if it was interchangeable before i waste my money fixing the a/c on the ls1 before i end up doing the swap when i come home for good
Just need to drill the hole in the mounting boss on the driver's side of the block for the alternator mount. You also need to use your oil pressure switch from the ls1.
