Will a 2.08 intake valve fit?
Old 03-11-2012, 09:35 PM
Monte LS....1's Avatar
Default Will a 2.08 intake valve fit?
Wondering if anyone knows if you can run or best way to find out if you can run a head with a 2.08 intake valve on a 5.3 or a 5.7? I've got a 5.3 already and if need be ill take it out to a 5.7 if the heads will fit, but don't want to find out the intake valve wont clear once I've spent the money for the heads. Any help would be appreciated.
Old 03-12-2012, 08:46 AM
MM98's Avatar
A 2.08 will cause more harm than good on that small of a bore.. A 2.02 is about as big as I would go on a 5.3 & 2.04 on a 5.7
