cam differences
Old 03-14-2012, 02:11 AM
baxsom's Avatar
Default cam differences
Recently, I posted a thread about a cam I purchased on a whim and got a lot of great answers but also new question that really needs a new thread.
I have the chance to swap my original cam for one a little smaller but since I am cam spec reading illiterate will someone please tell me the difference between these two cams and how they will perform. Goal is 400 RWHP and a stuck in traffic driver with a MN6 trans. Both are from Comp
Cam A. 228/228 .571.556 111 LSA
Cam B .232/240 .580/.580 113 LSA
I know there are a lot of people here who can just look at a cam spec and give a good estimate on how it will perform so hopefully one will chime in.
Thanks
Old 03-14-2012, 08:05 AM
bww3588's Avatar
both look half way decent, but I would go with http://texas-speed.com/p-1148-texas-...-camshaft.aspx
Old 03-14-2012, 08:18 AM
redtan's Avatar
One has more duration on the intake and exhaust and more lift. It will also produce more power at higher RPMs.
Old 03-14-2012, 09:26 AM
baxsom's Avatar
that is the cam i was planning on going with but i ran into these for less than half of what the 228R is running. guy bought the 232/240 one and decided he wanted to go forced induction so he changed it out after 5K miles
Old 03-14-2012, 09:30 AM
baxsom's Avatar
The big question though is, which one will be more drivable?
Old 03-14-2012, 09:48 AM
crainholio's Avatar
Generally, a cam w/ a larger Lobe Separation Angle will idle smoother and have better manners in traffic conditions. I ran a TR224 on 112deg LSA for years in stop 'n go traffic with no complaints, just as a data point.
Old 03-14-2012, 10:00 AM
disc0monkey's Avatar
cam B will drive better. if both lobes are equal
Old 03-14-2012, 10:10 AM
baxsom's Avatar
really, even though the bigger cam has more overlap, the wider LSA will be easier to drive? thats cool. Going on a C5 LS1 that is getting LS6 intake, AI heads, and long tubes. I guess I will keep Cam B and pass on Cam A.
