Looking for 6.0L head gasket specs...the real ones
Old 03-14-2012, 10:11 PM
MBC Racing's Avatar
Default Looking for 6.0L head gasket specs...the real ones
I keep seeing different specs for the GM MLS 6.0l head gaskets for the 4" bore 6.0. I am looking for the compressed thickness and the bore size of the gasket. I found 28-12589227 and it says .054" thickness. Then I see people posting about the gaskets being at .051 compressed..... Well, this starts to play into my calcs as to what my compression is. I also need the real bore size of the gasket as well.
Anybody have the real numbers? thank you!
Old 03-15-2012, 03:08 AM
93Z2871805's Avatar
The old gaskets off of my 6.0 were .054 (I measured thickness but I didn't check the bore). My new 046 gaskets are advertised at .051 (I went from 317s to LS3s). I'll measure up my old gaskets (and get the p/n) tomorrow for you. What heads are you using?
Old 03-15-2012, 07:53 AM
MBC Racing's Avatar
thanks. I will be using TEA 225 heads.
Old 03-15-2012, 12:09 PM
93Z2871805's Avatar
The gaskets I pulled from my 6.0 are 12569365 and measure 4.045 x .054. My heads are installed already so I can't get the measurement on the 046s for you. I hope this helps.
Old 03-15-2012, 02:06 PM
MBC Racing's Avatar
Thank you for the info!
Old 03-15-2012, 02:39 PM
Stumped1215's Avatar
ah I'd really like to hear what the newer 046 is.
Old 03-16-2012, 12:18 AM
93Z2871805's Avatar
From what I've seen the advertised compressed thickness measurements are right on, FWIW the 046s are advertised at .051 and 4.080.
Old 03-16-2012, 03:04 PM
.051 is exactly what I need. Who sells the 046 with that size? Speed inc sells them .055 advertised.
http://www.speedinc.com/catagory.cfm...in%20/%20Heads
Old 03-17-2012, 02:18 AM
93Z2871805's Avatar
Both Summit and Pace spec the 12610046 at .051 and 4.080.
Quick Reply: Looking for 6.0L head gasket specs...the real ones
