ls1 fuel injectors?
ls1 fuel injectors?
planning on getting these for my LS1 swap.
Will they work with the stock LS1 harness or will i need to do a mod.
also running stock LS1 Intake.
Will these do?
http://www.ws6project.com/user_stor/...-hr-injectors/
Will these do?
If you don't have any injectors at all, just do yourself a favor and start off with 36lb injectors...if you have a stock set just use them. Most stock were either 26 or 28 depending on year
Internet Mechanic
The plug is the same, Red tops, green top whatever you want. Just need to tune for them accordingly. Also, look for a LS6 intake, check the part #, better flowing, will make great power up to heads/cam.
I always liked Racetronix for fuel pumps and injectors. Sponsor ---->
If you ever plan on Nitrous go 42's all day.
