Fixing to assemble my first LS engine...anything special needed?
Just want to make sure my ducks are in a row. Going to pick up my LQ9 from the machine shop Friday. Not my first rodeo assembling an engine, but it is for a LS based one. Are there any do's, don'ts, or special tools that I need?
I have torque wrenches and stuff to degree the cam and check piston to valve clearance.
I had just read somewhere you needed a special tool to install the front and rear covers or their seals. Is this true?
Any help would be appreciated.
read: http://www.gmhightechperformance.com...ild/index.html
read it again. take your time and take all necessary measurements and be methodical. now get to it.
How far apart is the engine? I suggest a pushrod length checker and a valve spring compressor. Also do yourself a favor and get the Comp LS socket to put the degree wheel on.
http://www.ebay.com/itm/Comp-Cams-49...2b7040&vxp=mtr
Got mine from there and I swear it is the second best tool I have bought for my engine next to the Comp spring compressor tool.
I have an electronic Mac tools 3/8 torque wrench with built in angle meter that reads in lbs ft and lbs in. I know its not cost effective but I use it all the time
It's completely apart, still at machine shop. My degree wheel has several different bushings for different crank bolts, but that comp thing looks cool. I have a valve spring compressor to put on the checker springs.
Honestly didn't think about push rod checker since Pat G told me what length to buy when he specd my cam
Pat suggested me to use 7.425 pushrods and after measuring, found I needed 7.375. I'm not placing the blame on him one bit because every cylinder head, rocker arm, engine block, and cam lobe are different. It's a cheap tool and it's alot easier to measure all 16 then to be chasing your tail after it's all put back together trying to find what a certain noise is, why is it doing it, and what would fix it.
