243 61cc + f14 ??
243 61cc + f14 ??
will 61cc be compatible with the f14 (non high lift) cam 232/234 .598/.598. I've done some searching on this and I haven't came up with an exact answer (as i'm sure there is not). It looks like its gonna be pretty close. I will check clearance if i end up buying these. Just don't wanna buy something if its not compatible. i've tried calling Futral but no answer or callbacks. Thanks for your help.
Currently I'm running a vengeance racing vindicator cam and I know this cam and milled 243's won't work. I'm currently looking at a f14 because its hard to find heads to work with the vindicator. especially looking budget. I guess there is always flycutting.
If your going to pull the heads off, it's defintely worth flycutting and saving the trouble of pulling out that great cam you have there. You will regret if you pull it out for a smaller cam such as the f-14. Trust me on this, do it right the first time.
