ms3 or torquerv3 cam with 150 wet shot?? anybody running this set up??
ms3 or torquerv3 cam with 150 wet shot?? anybody running this set up?? i was thinking about going cam with nitrous, stock bottom end, anybody nunning this set up??? any numbers?? thanks
wow, Andy that GM article is amazing you have me very motivated to build your street machine. incredible. i want exactly what you want. my first questions is about your heads? what heads are those?? did you have them ported??? thank
Thanks man! My heads are stock untouched 853s, pretty much the same as the 241s. The stock motor will hold a ton of power if you say conservative and humble. You just don't have the room for error with a stock motor like you do with a built motor.
