Dyno Guesses on this 383
Old 03-19-2012, 09:48 PM
DSRE's Avatar
Default Dyno Guesses on this 383
Well i'm starting another NA 383 build and figured i'd run it through the boards to see about what power this should produce
2000 Z28 A4 3.42 gears 2800 stall 17" lw wheels
LS1 block 3.905" Callies 5140 4" crank Scat LW pro comp I beam rods with ARP 2000 bolts
Diamond Pistons -7cc Coated 11.55:1 with 61cc chamber
Hand Finished AFR 205's will have flow numbers soon
Custom Comp cam specced by me 231-231 .617 .617 111lsa 109ilc
ls7 lifters smith bros push rods
Yella terra 1.7 ultra light rockers
Fully Ported FAST 90 and FAST 90mm TB
36lb fast injectors LG long tube headers
moroso oil pan, billit timing set, electric water pump and 25% up
We arew definately building this to make good power everywhere and stay daily drivable so lmk what you think!
thanks
Old 03-20-2012, 08:43 AM
garcr4's Avatar
We just did a 383 ci short block by Schwanke with about 11.2 to 1 with Advanced Induction's best 243's with a similar cam (bit more duration).
Eagle crank, rods....Mahle pistons
stock rockers with the comp trunion upgrade, LS7 lifters
crane push rods
barnes single stage scavenge pump, with stock type pressure pump
Moroso dry sump pan
ATI dampner
It has a Holley 750 carb on a GMPP 4bbl intake similar to the Edelbrock victor Jr
This was for road racing, It made: 570 @ 6800 HP flywheel
477 @ 5600 torque
Max power would probably have been about 7200 but the MSD box was set at 6800. Will re-work that
Old 03-20-2012, 10:03 AM
JS01's Avatar
455rwhp SAE w/ locked converter.
Old 03-20-2012, 10:09 AM
RonSSNova's Avatar
I'm not too sure about pushrods made in Bend.....Oregon!
Sounds like a good combo to me.
Who is your machinest?
BTW, I am in Portland. You going to race at PIR or Woodburn?
Ron
Old 03-21-2012, 05:59 PM
DSRE's Avatar
Thanks Yeah we are going for 480+rwhp and i know its possible if everything is perfect i guess we will see!
i have a machinest that sets up everything exactly the way i want and we have a great relationship his name is Craig Bloom from Eastco Machine out of Gresham, I race at Woodburn and PIR, We have a Blown Alky 67 GTO we use to run every weeekend so i am always out there tuning or driving
Smith Bros makes some of the Nicest Push rods out there! they supply Top Fuel ect and i have never broken one Ever and I've Snapped other Big Name push rods, Plus i love keeping things local!
Old 03-21-2012, 07:10 PM
c5z16z's Avatar
thanks
good combo ,, very nice i like the static compression you decided to go with,,
do you know the exact cam specs do you have the cam card ,,do you know were you will be at with your static compression,,, good luck with your build
Old 03-21-2012, 09:04 PM
RonSSNova's Avatar
I have been racing at PIR/Woodburn since 1975. I know the GTO. And I have met Craig.
small world.
Good luck with the 383. I think 480 at the wheels is shooting low.
I will be using Smith Bros as well.
Ron
Old 03-21-2012, 09:38 PM
JS01's Avatar
Not really, it's truly a bit high IMO if we are talking dynojet SAE numbers on a 'real' dyno (calibrated w/ proper weather station setup). Through an automatic with a 'small' cam duration after all. Not to discredit the build, just trying to bring in some of my experience and another view point. Look forward to the results & I think it will have a solid power curve with great torque, sounds like a well thought out and solid build.
Old 03-22-2012, 11:58 AM
Nissan LS240's Avatar
487rwhp on my 383, 205 AFR's,callies crank, mahle pistons, callies rods, ls7 lifters, 92mm FAST, 11.2:1, M6, 4.08 gear, .619/242 T-rex cam think the specs are close to that. ATI damper, no power steering
Quick Reply: Dyno Guesses on this 383
