is this setup fine ?
Old 03-23-2012, 01:51 AM
Justinktm's Avatar
Default is this setup fine ?
would i be fine with this setup and no issues?
PRC Stage 2.5 5.4 CNC ported heads from TSP or PRC Stage 2.5 LS6 CNC Ported
Texas Speed Tsunami 235/240 .648"/.609" Camshaft or a tsp Torquer v2 cam 232/234 .595/.598
ls6 intake
42# injectors
4000 stall
150 shot nitrous
its going to be a nitrous motor so every bit of advice helps!!
would that be a good setup if not tell me what would be good to change or Improve?
Old 03-23-2012, 02:06 AM
99Bluz28's Avatar
I like the wider split of the TSP 233/239 for the NOS.
http://www.texas-speed.com/p-1154-te...-camshaft.aspx
If you want something with a little more lift then also take a look at the CompCams LSr cam #54-459-11, it's a 231(.617")/239(.624") w/113lsa.
http://www.ws6project.com/user_stor/...lsa-5-7l-6-2l/
Old 03-23-2012, 04:25 AM
Killer5.3's Avatar
ls6 intake
42# injectors
4000 stall
150 shot nitrous
If you plan on spraying much I would get your converter built based on your complete combo. The magic stick V3 is probably best choice for spray from the TSP line.
Old 03-24-2012, 12:28 AM
Justinktm's Avatar
wow 2 great cams right there i dont know which one would be better?
Old 03-24-2012, 12:36 AM
Justinktm's Avatar
i really like the TSP 233/239 but i already have a tv2 cam is it worth selling my tv2 and going to the 233/239
