LS1 head bolts. How do you know?
Internet Mechanic
Generally casting numbers off the block. Look towards the rear, near the lip where the bell house meets the block. Search here or Google.
As for bolts I would think it does not matter as your going to use ARP, no?
https://summitracing.custhelp.com/ci/fattach/get/44974/
^ Very Helpful
^ Very Helpful
I believe you got that backwards. The older models had the same length long head bolts and the later models had the different length. The easiest way to tell would be to measure the hole depth with a pipe cleaner and see if some of the block holes are shallower.
