AFR heads 225 vs TF 225 vs prc 227 heads
Im building a 383 stroker built for a 350 shot..My cam specs are 246/260 .629/.629 114+4 LSA I plan on spinning it too about 7500.. which heads would perform best with this set up I also have a fast 92/92 that I have too get ported..
LS1Tech Premium Sponsor
http://www.hotrod.com/techarticles/e...t/viewall.html
"The 237cc Texas Speed heads were dedicated castings that offered not only exceptional flow numbers but also additional head boltholes for use on the aftermarket LSX blocks. If you go looking to make a serious turbo motor with a set of cathedral-port heads, the extra clamping force offered by these extra bolts might be just what you need. The TS heads combined a 2.10/1.60 valve package with a 238/85cc port volume package to maximize airflow. Next to the AFR 245 heads, the TS heads offered the highest 0.500-lift flow numbers. Power production was every bit as impressive, and the average numbers were bettered only by the Trick Flow GenX head."
So PRC offers virtually equal power as the TFS heads and more than the AFR's for less money than both! Hard to argue with independent test results, although I'm sure some will
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Not saying anything bad about any of the heads so don't think I am. I'm just arguing Matt's statement lol.
OP, its pretty much brand loyalty here. They all perform great.
^^LOL! Thanks
As a side note, we don't spend any money advertising with that magazine or its affiliate companies.
__________________
Just lock this thread now becuase we all know that's where it's going. All of these threads where people ask "which is the better head" end up with a bunch of ******* bickering back and forth and provide hardly any "real world" numbers. My suggestion for you is to search on here for each prespective head and gather as much info as you can and make your decision based on that, your budget, your goals, etc. All three heads are great and you can't really go wrong with any of them.
Do you own the cam or is it what you picked out? Typically it is better to select the heads first, then the cam. Was cam designed around this much N2O? Should be a hell of a ride if you can get any traction.
On a 3.9" bore I dont believe any manufacturer has anything that can touch the PRC 227 heads. Remember the PRC 227 heads are available setup as a 3.9" bore. We basically set out to build the best max effort 3.9" bore head available.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
