03 LQ4+Patriot Stage 2 milled 59cc...P to V concerns
*SEARCHED*
I have a 2003 LQ that's going in a Rx7. this will be my DD and im looking cam it with something similar to a 228R.I will be using patriot heads milled to 59cc.
So my question is
What's the biggest cam I cam run with
Non MLS head gasket
Patriot Heads milled to 59cc
7.400 pushrods
Thanks in advance and I welcome any suggestions.
Thanks
So my question is
Non MLS head gasket
7.400 pushrods
Thanks
That's a hard question to answer. I would think mid 220s would give you safe PTV and low 230s would be cutting it pretty close, as in less then .100 clearance on both valves. That's a loose estimation of course.
Thats not gonna fix it at all lol. All that will do is make a lot of noise. Youre going to have to just measure and flycut if necessary. No way around that unless you go with a smaller cam. You may get away with it. Dont know until you try
Did you buy these heads new? I just wonder why nobody considers this before they go chopping the heads. Its like a viscous cycle. You mill off .035" to get over 11.5-1 compression which causing you to run a big cam to bleed some off, but you cant because of PTV issues which you now have to flycut.
@Badazz-these heads came out of no where for stupid cheap...i couldnt refuse them.Theyre used with about 5k.i knew my CR was going to jump.
i didnt think my cam was going to require flycutting which i wanted to avoid.Im gonna be using Non MLS head gaskets if that makes a difference.
-.6cc's on stock lq4 pistons u can run a 232 234 595 598 112 lsa cam with no piston to valve problems on 58cc's i did that for a couple of years and ran a consistent 12.2-12.3 @ 108-109 mph in a 5400 lb silvy 4:11s and yank ss3600 stall
