bigger ls1
Old 04-01-2012, 08:24 PM
jessebob99's Avatar
Default bigger ls1
can u go bigger than 383 stroker on ls1 without re sleeving it.
Old 04-01-2012, 08:56 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Due to the limitation on boring your bout at your max due to limitation on crank stroke. That's why most go to a LS2 due to getting a 4" bore. Also head options open up. Check with builders and you may get some more but at best you get a 0.010" over bore on newer ls1 blocks.
Old 04-02-2012, 02:27 AM
bww3588's Avatar
I think the biggest stroke you can go in a stock deck ls1 is a 4.100 for 392 cubes.
Old 04-02-2012, 10:46 AM
batboy's Avatar
You can install a 4.125" stroke rotating assembly (Lunati) into a LS1 that makes 395 CID. I would not recommend it though.
Old 04-02-2012, 04:59 PM
PREDATOR-Z's Avatar
It is possible (though not recommended) to open a LS1 to 4.00 bore. (Late model ls1 preferred for thicker sleeves)
Old 04-03-2012, 08:18 AM
dodson55's Avatar
if you re sleeve a ls1 yes you could go to a 4 in bore but on stock sleeves no
Old 04-04-2012, 03:54 PM
PREDATOR-Z's Avatar
Read above again. It has been done. Running LS2 rods/pistons stock crank. Granted it takes guts to play with those margins but it is doable (on late model LS1s)
Old 04-04-2012, 07:18 PM
Rlncoalctd's Avatar
Is a 383 really going to make much more power over a 347?
Old 04-04-2012, 08:02 PM
Rlncoalctd's Avatar
Reason why I ask is because some people arent even breaking 500rwhp with a 383, yet some guys are getting 480 out of stock shortblock engine.
If you take a set of TEA/TFS 215's, a 236/242 615/615 on a 111, fast 90/90 people are reporting 470-490rwhp. How would that setup perform with a few more cubes?
Quick Reply: bigger ls1
