2.08/1.57 Valves in a 799 heads question.
Old 04-02-2012, 11:28 PM
fastsspr's Avatar
Question 2.08/1.57 Valves in a 799 heads question.
2.08/1.57 valves can fit in the 799 heads if i change the valve seats?
You think is a good idea in a 6.0L block .030 over?
Thanks for your input.
Old 04-03-2012, 07:36 AM
redtan's Avatar
PRC stage III LS6 heads come with 2.08/1.60 valves, so yes it can be done.
http://texas-speed.com/p-1177-prc-st...ted-heads.aspx
Should work well in a 4.030 bore.
Old 04-03-2012, 09:47 AM
01ssreda4's Avatar
With nothing else being done to the head it isn't worth the trouble IMO.
Old 04-03-2012, 10:39 AM
KCS
Moderator
KCS's Avatar
Is it a racecar or mostly street car? That valve size might be a little big for a 370ci daily driver, but it's not a bad idea for something that will see WOT pretty often.
Old 04-03-2012, 06:50 PM
SVTconfused's Avatar
My 853 heads have 2.08 1.64's
Old 04-06-2012, 08:49 PM
fastsspr's Avatar
The heads are fully ported !!!
It is most of a race car it going to see street driving very few times. For now the set up is 6.0L with Diamond flat tops .030 over and eagles rods 6.125 a MS3 cam with edelbrock 1 3/4 stepped to 1 7/8 headders ,4500 stall in a
th400 with t/brake and 8.8 rear with 4.10 and a like 200hp shoot.
Old 04-07-2012, 08:22 AM
KCS
Moderator
KCS's Avatar
Sounds like it will be a beast. I don't know about the MS3 though. If I remember correctly, the lobes are on the aggressive side and may not like heavy 2.08" valves.
Old 04-08-2012, 08:01 PM
fastsspr's Avatar
How a lobe can be not like a heavy valve? What you mean with that ?
Quick Reply: 2.08/1.57 Valves in a 799 heads question.
