which cometic head gasket and why?
I'm getting ready to order head gaskets and I'm trying to figure out which cometics to use with my set up. There seem to be many options cometic offers for an LS1. Which gasket would yield the best performance gains?
This is what i have:
stock bottom ls1
comp 228/230 .571/.573 112lsa (intake 71* abdc)
ported unmilled 799 heads with stock valves
cometic gaskets:
part# / compressed thickness
C5475-040 (.040")
C5475-036 (.036")
C5475-030 (.030")
C5475-027 (.027")
stock bottom ls1
cometic gaskets:
C5475-040 (.040")
C5475-036 (.036")
C5475-030 (.030")
C5475-027 (.027")
I would not go thinner than .040" due to reduced quench clearances and due to the thinner you go the harder they are to seal. Personally, I like the GM MLS gaskets.
With stock pistons id use the .040" gaskets, i'm using a .027" cometics gaskets but iv also got -8cc dish pistons, if had a smaller dish piston would've used a .040" myself.
I'd also use the .040". On average your piston sits around .005" up out of the hole so that would give you a .035 quench..035-.030 is optimum, when you get tighter there are gains, but as the metal stretches and expands it leaves less room for error.
