Bearing Clearances
Bearing Clearances
What are ideal bearing clearances for an ls1 used as a weekend warrior. High revving(7k rpm) want the motor a little loose but There are quite a few opinions. So i was wondering what would be good clearances for the main and rod bearings. Its more of a street strip car. meant for 10's
you are going to get a few different answers on this one...
factory specs on rods are .0009"-.0025". set your rods up at .0023"-.0028"
factory specs on mains are .0008"-.0025". set your mains up at .0025".
like i said im sure you will get alot of different answers on this on... just my 2 cents
Here are a couple sources.
Main Bearings (Aluminum Block)
1. Tony Mamo, 0.0017" - 0.0019", https://ls1tech.com/forums/generatio...clearance.html (Post #6).
2. Joseph Potak, 0.0015" - 0.0020", "How to Build and Modify GM LS Series Engines" (Page 40).
