Hand ported 243's. Pics and flow sheets
Old 04-06-2012, 11:50 AM
MonmouthCtyLS7's Avatar
Default Hand ported 243's. Pics and flow sheets
Heads are low miled off of a 01 Z06. Will be running Manley valves w/ them.
Intake Before & After
Exhaust Before & After
Old 04-06-2012, 06:59 PM
Damn I got this info for some of ya and no responses lol
Old 04-06-2012, 07:02 PM
99fbodyTA's Avatar
oh damn!!!!
Old 04-06-2012, 07:13 PM
studderin's Avatar
i think you have the sheet listed wrong.
a cly head shop did that?
Old 04-06-2012, 07:14 PM
Wherever he had them flowed at did....not his shop
Old 04-06-2012, 08:39 PM
Thumper28's Avatar
When you flow tested them did they give any data to show that all ports are flowing relatively the same. That's what I would be worried about with a hand port?
Old 04-06-2012, 08:45 PM
Z28SteveA4's Avatar
how ended up doing the port work for you??
Old 04-06-2012, 09:23 PM
99fbodyTA's Avatar
just make sure they are all flowing evenly, since it was hand ported
Old 04-06-2012, 10:17 PM
Tom01ss's Avatar
Default head porting
these heads were flowed by jewels schonberger of philadelphia racing engines. a very close friend of mine. he is very knowledgable in race engines.
Old 04-07-2012, 06:13 AM
Tom01SS two posts below you did/ is doing the port work.
Old 04-07-2012, 08:21 AM
Thumper28's Avatar
But How do you do this. Can they check for this when they flow test?
Old 04-07-2012, 08:29 AM
Well I think all they would do is compare the flow rates of both heads after porting... Id imagine its never exact but for someone that knows what there doing its probably close...or close enough.
Old 04-07-2012, 09:08 AM
KCS
Moderator
KCS's Avatar
I think you have the pictures labeled wrong. The first two are your intakes (Test Port 2I), with the top page after porting and the bottom page before. The second two are the exhausts (Test Port 2E) in the same order.
Old 04-07-2012, 09:35 AM
Fixed, Thank You !!!!!!
Old 04-07-2012, 10:53 AM
studderin's Avatar
ya, thats what I ment.
Looks like someone 1st time working on that head, don't mean that in a negative way. But an observation on how the port is shaped. And how you will tend to grind it, on for what easy/comfortable with the grinder. Where is the finished pics?
Old 04-07-2012, 01:59 PM
Tom01ss's Avatar
Default heads
those are rough pics , the heads were flowed in the finish state. my names tom of evil performance and transmissions any questions please call me 610 931 0540. thanks guys
Quick Reply: Hand ported 243's. Pics and flow sheets
