what kind of power am i looking at?
Old 04-09-2012, 08:42 PM
christiandoy's Avatar
Default what kind of power am i looking at?
241 heads ported and polished
harlan sharps non adjustable 1.7
3.905 wiseco pistons
6.125 h beam eagle rods
4.00" eagle crank with 24T reluctor wheel
Dual AFR Valve springs rated up to .650 lift
custom grind Ed Curtis cam 242/250 .622 with 114 lsa
ls6 ported oil pump
ls2 timing chain
3 angle cut valves
texas speed 7.375 chrome moly pushrods
what do you guys think I'll be getting to the wheel?
Old 04-09-2012, 08:48 PM
SSmoked1's Avatar
That's a massive cam for stock cubes. Fast intake? Rod bolts? What headers and exhaust? Auto/Manual?
Old 04-09-2012, 08:55 PM
sorry, not stock cubes
it will be a 383 stroker motor
arp rod bolts
arp head bolts
long tube stainless headers straight piped
ls6 intake with 42 pound injectors
Old 04-09-2012, 09:15 PM
bwilde86's Avatar
Is an intake in your near future? The ls6 is going to rob some power.
Old 04-09-2012, 09:18 PM
looking into a 92/92 fast
but without that
what do you guys think are good, safe numbers?
Old 04-09-2012, 09:49 PM
SSmoked1's Avatar
I'll say 450/410. Heads and intake are really hurting.
Old 04-09-2012, 09:51 PM
fully ported and polished 241 heads will hurt that much?
Old 04-09-2012, 10:02 PM
SSmoked1's Avatar
Not the heads only but a combination of heads/intake. 241's can flow pretty good depending on who ported them. I'm stock cube with a big cam and trick flow heads. I lost a lot on top end cause of the ls6 intake. Not to mention it just fell off at about 6700 rpm. I have a FAST 90/92 now and its a big difference. Just my .02
Old 04-09-2012, 10:11 PM
Z28SteveA4's Avatar
is the car auto or manual? this will be a big factor on horsepower numbers as well. With your setup the ls6 will be robbing big numbers from your hp. The ls6 is a good intake for a cam only or a less aggressive head cam package not for your set up. That cam is going to want to breath and they only way to fully feed it is a fast setup. Those heads are questionable too. Why do you plan on putting the money into a 383 and not into a good pair of heads? Its doesnt make sense to me. What are your plans for this car?
Old 04-09-2012, 11:05 PM
t56 manual
Old 04-09-2012, 11:31 PM
Steve honestly why does everyone crap on 241 heads? They are really not that bad with the right amount of porting done to them.
Old 04-10-2012, 05:26 AM
mark21742's Avatar
With the tight work done to 241's they might fall 15hp below s high dollar head.....if you are looking at getting EVERY last bit of power at whatevet cost, then I could see spending the money on great heads.
You'd have to do a search on it, but there are some companies out there that offer a chopped ls6 intake with 90mm tb mount and larger throat, BBK has there aluminum intake that falls about 10hp short of the FAST....sometimes you can get a great deal on a used FAST when someone feels the need to go up to the 102mm. I just can't see paying $1,000 for a peice of plastic to spin the engine 2-300 rpm more.
Another option if you need a FAST is to get on EBay and find the three prices separate
Old 04-10-2012, 08:00 AM
redtan's Avatar
Too many variables to say...who ported the heads? What is the final compression ratio?
Old 04-10-2012, 08:10 AM
R6cowboy's Avatar
ls6 ported oil pump
ls2 timing chain
3 angle cut valves
A few things that will get you much better answers: 1) specify the head work 2) compression ratio 3) intake set up 4) drivetrain
How do you come up with stock cubes with a 4.00" crank?
Old 04-10-2012, 08:51 AM
Nissan LS240's Avatar
made 497hp with my 383, afr heads, fast intake, .619 236/242 111, 11.2:1 cr,
Old 04-10-2012, 02:40 PM
Nissan LS240 i am doing the exact same conversion as you man!
Old 04-10-2012, 02:50 PM
well then, expect to break diff(now Q45 diff), subframe bushings(now solid), and if your running stock springs, and wide tires, the first time you get on it you might cut a tire, that's what has gone wrong so far with the 240, I also broke the clutch, broke the tranny (my fault) and fuel cell leaked fuel, but when everything's right that car is stupid fast and loads of fun, I ran the sikky 1 3/4 headers, x pipe, 3inch dual exhaust all the way back no cats through some borla xr-1 mufflers, good luck on yours
Old 04-10-2012, 03:03 PM
that's awesome
What kit did you go with for the mounts and what pan?
who did your wiring and did you convert to a 5 bolt setup?
Old 04-10-2012, 03:11 PM
Midnight02's Avatar
I would think you would be in the 430/440 rwhp range with that setup. Definitely some upside of matching a better intake with that combo.
Perhaps your leaving some power on the table with the 241 heads however it's tough to say anything with certainty without knowing what work was done to them.
Old 04-10-2012, 03:18 PM
might be sealing the deal on some 243 heads for 100 bucks
Ill let you guys know
