Any tips for removing broken bolts + ease outs?
Old 04-09-2012, 10:29 PM
streetknight2's Avatar
Default Any tips for removing broken bolts + ease outs?
Ok guys. I bought a LQ9 pull out the other day. Was planning on putting it in my car to get me by till my other engine is ready to go.
Well, it has a broken exhaust bolt in each head. I lubed them up with PB blaster and let it set for a couple of days. Drilled them and broke ease outs into BOTH OF THEM. Needless to say, I'm pretty bummed. I was trying to avoid pulling the heads off.
Any ideas? I've tried to center punch the broken ease outs and drill them, but oh no, they're hardened and not cooperating.
TIA
Old 04-09-2012, 10:54 PM
SS1Eagle's Avatar
As crazy as it sounds, use a flame to heat the bolt then apply candle wax. The heat will suck the wax down the threads and lube the bolt up.
Its broken loose stuff I thought would never come off.
If that doesn't work, take a chisel and hammer and make an indentation on the bolt. Then try tapping it with the hammer and chisel counterclockwise to see if it will turn. If you can get it turned out a few turns this way, you might be able to get a vise grips on it and take it the rest of the way out.
I used WD-40, Liquid Wrench and CRC but the best in my opinion is Kroil. Read the reviews on the aerosol oil penetrant.
http://www.amazon.com/Kano-Aerokroil...sim_sbs_auto_2
Old 04-09-2012, 11:09 PM
SS1Eagle's Avatar
Unless you have pics of your problem this video is worth checking out.
http://youtu.be/ebQdfqAmyt4
Old 04-09-2012, 11:27 PM
gMAG's Avatar
I would take a reinforced dremel cutting wheel, and slice off (flush with the top of the bolt) any remnants of the easy-out.
Then, take a used, smaller diameter of the same wheel, and cut a groove (like a screwdriver groove) in to the top of each bolt.
Heat the bolt with a propane torch (I wouldn't do this on an aluminum head).
Use a screwdriver bit and extract the bolt.
Old 04-10-2012, 01:16 AM
scj
scj's Avatar
I've removed exhaust manifold bolts with a drill bit and an easy out, breaking one off seems like there was way too much force applied to the easy out, I used my easy out with an attachment from a tap set.
Old 04-10-2012, 04:09 AM
bww3588's Avatar
Weld a nut to it if something is sticking out to weld to, and use the candle wax method while turning it out. Just be careful not to warp the aluminum head.
Quick Reply: Any tips for removing broken bolts + ease outs?
