Valve train questions.
Old 04-10-2012, 09:32 PM
Jester1225's Avatar
Default Valve train questions.
I just purchased some 243 heads. I am looking at a couple cam choices but I am reserved about my rockers. Can I go with some 1.8:1 rockers or stick with a stock 1.7 layout for proper valve clearance. The cams all have a mildish lift of .588 int/ex. This is for a stock ls1 btw
Old 04-11-2012, 05:09 AM
vettenuts's Avatar
I would look more at the ramp rate of the cam rather than the lift in determined whether to go with the 1.8's. If it is a fairly fast ramp like an XER I think I would personally stick with 1.7's and spend the time to properly set them up.
Old 04-11-2012, 10:00 AM
batboy's Avatar
I'm not a big fan of the higher ratio rockers, it throws the valve train geometry off and is hard on the valve train. Just find a cam with the desired lift.
Old 04-11-2012, 04:09 PM
Jester1225's Avatar
Thanks for the replies. On a different note does anyone know of anywhere that would port my heads in the nc/sc area and not charge an outrageous amount of money?
Old 04-12-2012, 04:33 AM
vettenuts's Avatar
Don't know anyone but if I had a set of 243's and wanted work done to them, no question they would go to AI. Their results speak for themselves. Do them once and do them right.
Old 04-12-2012, 07:12 AM
SweetS10V8's Avatar
Instead of more rocker ratio, just get a bigger cam and stick with the 1.7s
