Valve Covers and Crankcase Pressure
Old 04-11-2012, 04:20 PM
Chrishbsbll's Avatar
Default Valve Covers and Crankcase Pressure
Does having valve cover that just have the cap on one side bad for crankcase ventilation/pressure? Also what do you do with the PCV lines from the driver side valve cover and the top of the pass side cover?
Old 04-16-2012, 09:53 AM
I guess what I am trying to ask is... Can you run valve covers with just one breather hole on one side? If so is a catch can needed?? Or can the PCV system be deleted??
Any help would be appreciated!!!
Old 04-16-2012, 10:26 AM
mark21742's Avatar
Yes you can run just one hose off one valve cover and be fine up to I think 450-500 HP, after that you want to run one off each valve cover or the valley pan cover.
A catch can is always a great idea...keeps oil mist off the track and out of your intake.
Old 04-16-2012, 03:03 PM
thanks man, do they have to circulate back into the intake or can you run a breather filter on them?
Old 04-17-2012, 07:34 AM
BIG_MIKE2005's Avatar
Search catch can routing in the external section. Tons of info there.
