buy better heads, or save some for fast intake?
Ok, so I've looked at some heads, and the 5.3 ones are the cheapest, then the ls6, then the prc 227. Now my question is this, for my budget on this build, should I go with cheaper heads and a fast intake or the better heads without the fast intake?
My thinking is id be wasting money on great heads only to restrict them with the ls6 intake I have (and no money left for new intake). So should I save some cash with the 5.3 or ls6 heads, and throw on a fast intake?
I'll 3rd it.......later down the road you can drop the new intake on your engine with great heads in a few hours at the most, and you won't be kicking yourself wondering IF the better heads would have made more of a difference. Great heads now, intake later
3 to 5 hp???
New heads will yield you alot more than that. Intake is a waste of money if the heads don't flow well.
FAST should be the last thing to do and heads will give you way more than 5hp, and more than a FAST intake. Heads are a must and ALWAYS PERFORMS compared to the FAST intake, which might give the internet numbers some plp are looking for. A FAST setup can be anywhere from 0-35rwhp(ported/matched and the bigger TB)..
Unless you dont wanna lift the heads..it should not be a question IMO. Good luck either way.
