Pete Jackson gear drive for LS1
I noticed in the new Jegs that Pete Jackson is making gear drives for the LS1, since I am going back into my engine I am thinking about ordering one. Has anyone tried one yet? With a gear drive thats just one less thing to worry about....
I'm looking in my latest Jegs catalog and I don't see a Pete Jackson gear drive for the LS1. I see one listed for SBC EXCEPT LT1, LT4 and LS1 but nothing specifically for the LS1. And I don't see how a gear drive could be used. The knock sensors would go crazy.
Im really wanting to check this out.
-Corey
I had 2 of them a couple of years ago, a noisy one on a 355 sbc, then a quiet one on my 468ci bbc, and the quiet one on the bb was way louder than the other. They are nice pieces, but like others are saying I'd check into the nock sensors picking them up as false knock. I wouldn't think they would because the sound would be more like loud valvetrain if anything. They may have improved them for our engines, putting small holes or different tolerances between the teeth to allow the air to escape. Definately be worth checking out, I can see it now people will be accusing me/fast ls1 cars of running a SC at the track instead of nitrous now lol
-Sly
-Sly
http://www.jegs.com/cgi-bin/ncommerc...54&prmenbr=361
782-350-91C SB-Chevy Gear Drive
1987-2004
350ci with Factory Hydraulic Roller Camshaft
Is this it?
1987-2004
Is this it?
From the Illustrated Sourcebook of Mechanical Components:
BELTS
While the supercharger drive, racing application is highly visible and glamorous, the same polyurethane belt is used in industry to replace roller chain on a wide variety of applications. Roller chain requires lubrication and regular maintenance in order to perform at its peak level. Roller chain can stretch up to 3% of its length over the life of the chain. The Kigh capacity, polyurethane synchronous belt provides superior horsepower capacity, with virtually no stretch.
Additionally, no lubrication is necessary with the synchronous belt. The lack of lubrication allows the polyurethane synchronous belt to replace roller chain on applications where cleanliness is necessary to prevent contamination of product.
One of the advantages of synchronous belts is their very high efficiency.
Even though properly maintained V-belts drives can run as high as 95-98% efficient at the time of installation, this often deteriorates over time by as much as 5% during operation. Poorly maintained V-belt drives may be up to 10% less efficient. Synchronous belts remain at an energy efficiency of around 98% over the life of the belt.
I can't find the reference right now, but I believe chains are just as efficient (maybe 1% less) as synchronous belts, and gears are at least 2% less efficient.
BELTS
