Head Bolt Thread Chasers - LS1TECH
Thread Tools Search this Thread
Old 04-21-2012, 11:27 PM   #1
Default Head Bolt Thread Chasers
Is ARP the only company that sells these? Or is there just a more correct term for the part?
I assume others make them for considerably less $$$
badazz81z28 is offline   Reply With Quote
Old 04-22-2012, 12:47 AM   #2
trans_am7935's Avatar
just use and old head bolt, and grind an offset ditch in it, its free! like this:
worked great for me!
trans_am7935 is offline   Reply With Quote
Old 04-22-2012, 01:28 AM   #3
I dont want to risk dicking up my aluminum block. I can cut a bolt like that, but where it's cut, there will be burrs that will not allow it to smoothly tap in.
Old 04-22-2012, 01:40 AM   #4
take a wire wheel to it afterwards, or a metal brush and take off all the bolt threads. lots of people have done it this way as this is how it is described to do it on LS1 how-to. it is you motor and is up to you, but this is the free way to do it.
i mean if you are really that worried, send me your address, i will go dig up the one i used, i am sure it is clean by now
Old 04-22-2012, 06:01 AM   #5
Grooving my bolts took nothing out of the holes. I ended up buying the thread cleaning tap from ARP and removed a lot of old tread lock that the bolt didn't grab. I even had to re-vacuum out the holes to get the additional thread lock dust that fell to the bottom. I was really meticulous about this as stripping a hole was my single worst nightmare. My heads went on yesterday.....flawlessly.
And yes, they seem to be the only people that make the tool. Don't use any tap because most all will cut threads (remove metal) vs just clean them.
kmetros is offline   Reply With Quote
Old 04-22-2012, 08:33 AM   #6
vettenuts's Avatar
I bought the ARP thread chasers as well. They work much better than the cut bolt. No tap.
vettenuts is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
delete CyberGrey Z28 Parts Classifieds 3 05-06-2014 11:06 PM
Sold jetaws6 Parts Classifieds 13 05-06-2014 02:37 PM
Sold!! jeremyfrank14 Parts Classifieds 0 04-08-2014 09:30 AM
delete ELDIABLO Generation IV Internal Engine 0 10-30-2013 05:45 PM
Tags
arp, bolt, boltthread, buy, chaser, chasers, clean, head, heads, ls1, lt1, make, package, tap, thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
