What rockers under stock valve covers?
Old 04-22-2012, 03:02 PM
salemetro's Avatar
Default What rockers under stock valve covers?
After using search and reading for a while, I'm still left scratching my head on this one....
What are the best 1.7 rockers (adjustable or not) that will fit under a stock valve cover? I've been looking at Jessel, YT, HS, etc, but am not sure which way to go to keep it all under the stock cover.
Old 04-22-2012, 04:04 PM
SF 1HOTLS1's Avatar
I here some people say YT and HS require getting that spacer for the stock valve cover. you can always just keep your stock rockers and upgrade them with the comp cams trunnion mod.
Old 04-22-2012, 05:02 PM
Darkman's Avatar
Jesel Sportsman Shaft Mounts (non-adjustable), Yella Terra Ultralites, and some of the Harland Sharp rockers are designed to fit underneath the stock valve cover. There may be exceptions, and there may be cases where you actually need to file or Dremel a place or two to make it work.
I would also be concerned with selecting a rocker that will handle the spring pressure. For example, the Jesels are rated to 900 pounds of open spring pressure, whereas the Yella Terras, (and stock rockers for that matter) are only reliable up to 400 pounds of open spring pressure.
Old 04-22-2012, 05:12 PM
salemetro's Avatar
I already have the trunion upgrade....swapped cams and looking for a better swipe pattern. Spacer for the valve cover? Ill have to do some more searching....
Old 04-22-2012, 05:15 PM
Darkman's Avatar
http://www.summitracing.com/search/b.../?autoview=SKU
salemetro's Avatar
Thanks for the heads up.....im at 400 closed. Which jessel's are you meaning?
Old 04-22-2012, 05:17 PM
salemetro's Avatar
Thanks for the link!
Old 04-22-2012, 05:25 PM
Darkman's Avatar
Jesel KSS-307070
http://www.summitracing.com/parts/JES-KSS-307070/
(The Summit picture shows an adjustable version, but these are not adjustable).
Old 04-22-2012, 06:04 PM
salemetro's Avatar
Jesel KSS-307070
Chunk o $$$....but gonna have to throw down the funds if that's all that is available. Thanks :-)
Old 04-22-2012, 06:23 PM
ZeeOSix's Avatar
... the Yella Terras, (and stock rockers for that matter) are only reliable up to 400 pounds of open spring pressure.
Where did the 400 lbs open spring pressure specification come from for the stock rocker arms?
Old 04-22-2012, 06:45 PM
Darkman's Avatar
https://ls1tech.com/forums/15983303-post14.html
https://ls1tech.com/forums/generatio...ough-idle.html
https://ls1tech.com/forums/generatio...ke-rocker.html
Quick Reply: What rockers under stock valve covers?
