231/237 and a 2.04 intake valve. P/V?
Old 03-26-2004, 09:32 PM
goinbroke's Avatar
Default 231/237 and a 2.04 intake valve. P/V?
Will this clear? Has anyone run the tsp 231/237 cam with a 2.04 intake valve and cleared? Heads are 5.3 and unmilled.
Old 03-26-2004, 10:33 PM
gomer's Avatar
I ran the 231/237 on some LS6 styles unmilled with a 2.055 intake and was ok.
Old 03-28-2004, 12:58 PM
goinbroke's Avatar
thanks gomer. I guess it should clear then.
Old 03-28-2004, 06:58 PM
poncho99's Avatar
i called patriot about the same question and they told me that a 213/237 witha 590 lift will fit on a 5.3 head
Old 03-28-2004, 08:50 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
It will clear no problem with a 2.04 valve
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 03-28-2004, 09:20 PM
MADCOW's Avatar
That's good news. I've been planning on ordering this cam with my new absolute 5.3 heads(unmilled).
Old 03-28-2004, 09:26 PM
DenzSS's Avatar
Just make sure you check it during install regardless. You can always end up with one of the engines that has a higher piston protrusion than normal. I don't know how much clearance that cam usually has.
Old 03-28-2004, 10:52 PM
goinbroke's Avatar
thanks for the reply's everyone. Looks like it should clear.
