Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation III Internal Engine
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
1997-2006 LS1 | LS6
Sponsored by
Texas Speed & Performance
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 04-25-2012, 09:38 AM   #1
1999 Chevrolet Camaro
1bad99's Avatar
Trader Rating: 0
Default Just had motor rebuilt! Please Help
Ok so this is def something that i wasnt want to post but you guys are the s*** when it comes to LS engines. So i put all kinds of goodies in my motor, Cam,springs, oil pump, timing chain, LS7 lifters, ond others, but ive just rolled 1,000 miles and i cant help but notice a slit tick or tap in the engine. Its not loud but def noticable and driving me crazy. My bud who built the engine was pretty confident on the build but this noise, to me shouldnt be there. A couple people say that my lifters might not be pumping up like they should. I checked the torque on the rockers hoping one had backed off but NOPE! Whats you guys think it could be. I built the motor for boost and IMOP dont think that i should put turbo on till i get further advise on what is goin on. Please any advise.
1bad99 is offline   Reply With Quote
Old 04-25-2012, 09:46 AM   #2
Garage is empty, add now
conan's Avatar
Trader Rating: 0
Did you check for push rod length with all the new parts ? Did you replace exhaust manifold gaskets ?
__________________
2000 / Z28 / M6 / 383ci ls1 / D1SC / Under construction
Z28 pics The New Set Up http://camaroversion20.shutterfly.com/
Z28 pics -Version 1.0 http://mycarpics.shutterfly.com/?role=-1
04 Duramax- DD
http://ls1tech.com/forums/forced-ind...ys-update.html
conan is offline   Reply With Quote
Old 04-25-2012, 10:02 AM   #3
1998 Chevrolet Camaro
Trader Rating: 0
Is it bottom end noise like a spun bearing or what kind of noise is it and where does it sound like it is coming from. One of my buddies just built a engine not too long ago and spun a bearing in about that length of time started as the slightest noise that barely anyone could hear but him but then it finally became a lot louder and it was easy to tell what it was. Also like conan said did you check your push rod length? and could be exhaust gaskets those are a pain in the a$$!
el33tprodigy is offline   Reply With Quote
Old 04-25-2012, 10:19 AM   #4
1bad99's Avatar
Trader Rating: 0
The push rods come in the Cam Kit i bought from Texas Speed, so rods and springs were provided. And the noise is in the top of the engine .Its not a knock just a slight tap. But i do have a exhaust leak due to BS exhaust pipe. While the engine was out i replaces all barrens. And yes new header gaskets.
Old 04-25-2012, 10:22 AM   #5
Trader Rating: 0
Could be the exhaust leak your hearing get that fixed first and then see if it is still there.
Old 04-25-2012, 10:24 AM   #6
Trader Rating: 0
A brand new bearing can still fail in the first 1000 miles happens probably more than you might realize if for example wrong torque was used or something along those lines. I would first get that exhuast leak fixed first though. Sorry for two posts forgot to mention about the bearing though.
Old 04-25-2012, 10:32 AM   #7
1bad99's Avatar
Trader Rating: 0
Its cool man and no i didnt think about the barrens goin out and would hope like hell it didnt. but im working on the leaks kinda hard to get lil time with my job.
Old 04-25-2012, 10:39 AM   #8
MT0911's Avatar
Trader Rating: 0
It would be best if you provided a Video with clear sound. It could just be that infamous sewing machine tick that almost everyone has.
Is the tick consistent?
Is the tick deep in sound like a knock?
Is the ticking sound very light like a quiet tapping noise?
Does it get faster as rpms increase?
Does it get louder as rpms increase?
Answers to these would be helpful as well. Good luck man!
__________________
'99 SVT Cobra - 283 C.I. WAP Forged Block, HP Custom Blower Cams, Novi 2000rr (8-Rib), RPM T-56, SRA Swap
'99 C5 Corvette FRC - H/C/I/E + Suspension
'04 Silverado 2500HD - I/E + Tune
'02 Mustang GT - Exhaust, 4.10's, Suspension SOLD
MT0911 is offline   Reply With Quote
Old 04-25-2012, 11:28 AM   #9
1bad99's Avatar
Trader Rating: 0
Yes
No to deep sound
Yes its is quite
Yes
Yes
Old 04-25-2012, 11:29 AM   #10
1bad99's Avatar
Trader Rating: 0
I do hear the sewing machine sound like a few friends of mine but i just thought that it was the dual beehive springs provided with the kit.
Old 04-25-2012, 11:38 AM   #11
MT0911's Avatar
Trader Rating: 0
^ Ok I'm betting it's just the infamous sewing machine tick. It's really common in LS1's. You'll know if it's a lifter because the tick will be loud and easily heard outside the car with the hood closed. If it was a spun bearing then it would be a bit deeper and have a "chugging" pattern in the sound.
I don't think you have anything to worry about. If you are paranoid - grab a mechanic's stethoscope and place it on the valve covers on top of each cylinder and listen for irregularities. If they all sound the same and all you have is a very light, quiet tapping noise then I wouldn't worry about it. Getting used to the louder valvetrain in these Ls motors is one thing some people never get used to.
A short video with revs would still be very good just to confirm.
__________________
Old 04-25-2012, 11:55 AM   #12
1bad99's Avatar
Trader Rating: 0
click on pic to watch video
Old 04-25-2012, 03:20 PM   #13
1bad99's Avatar
Trader Rating: 0
I hope thats clear enough if not ill try to get another one.
Old 04-25-2012, 03:42 PM   #14
PowellSixO's Avatar
Trader Rating: 0
Sounds like a lifter not pumping up to me. I could be wrong. I would pull the valve cover on the side that the sound is strongest, and look and see if one of the rockers isn't getting oiled. If one isn't getting oiled then I would say that you have a lifter that isn't pumping up.
__________________
07' 2500HD Classic 4x4
6" Fabtech lift, 325/60/20 Nitto Terra Graps, 4.88's, CIA, Cat back dual exhaust, and 220/218 .581"/.562" 111 LSA cam, BBP tune, 8.1 injectors, and my cats ran away.
http://i284.photobucket.com/albums/l.../DeBadged3.jpg
PowellSixO is offline   Reply With Quote
Old 04-25-2012, 06:52 PM   #15
TransamGCS's Avatar
Trader Rating: 0
hard to tell from video clip could just be the sewing machine noise thats common when you go to a more aggressive cam i would strongly urge you to buy a push rod length checker and re check pushrod length just cause tsp sent you the rods with the cam doesn't mean they are the proper length they sent pushrods with my cam and heads that i bought from tsp and they ended up being to short if i had just went with what they sent i would have beaten my valve train to death and im sure the sewing machine noise would have been loud as hell, i ended up trading them in for longer ones. so if you measure and they are correct than thats one thing you can cross off the list
__________________
2000 Arctic White TransAM, Prc 215, MS4 Cam, SLP Under Drive Pully, SLP oil pump & double roller chain, FAST 102 intake, FAST 92mm Throttle Body, FAST 42 lbs injectors, Racetronix fuel pump, SLP intake, OBX headers, Off road Y, LS7 clutch, Mike Norris Tune
TransamGCS is offline   Reply With Quote
Old 04-26-2012, 07:23 AM   #16
1bad99's Avatar
Trader Rating: 0
Ok Ill pull them this afternoon and see what i can find. Thanks!
Old 04-26-2012, 07:38 AM   #17
Old Geezer's Avatar
Trader Rating: 1
Send a message via AIM to Old Geezer
Cut the oil filter open and see what may be there....
__________________
Chuck
Hot rodding and drag racing since 55
55 Chevy/LQ9 Tyr Fryer
Turbo Buick in the 9's/142mph.
Old Geezer is offline   Reply With Quote
Old 04-26-2012, 08:13 AM   #18
mark21742's Avatar
Trader Rating: 0
How many turns from 0 lash to torque are you putting on the rockers? That could tell you really quick if you have the right length pushrods....stock should be around 1 1/4-1 1/2 turns.....I have mine set up and pretty quiet at 1/2- 3/4 turn from 0 lash to torque
mark21742 is offline   Reply With Quote
Old 04-26-2012, 08:55 AM   #19
Trader Rating: 0
In my opinion it is either a lifter not getting oil up or a bearing. Kind of leaning towards a bearing but that could be false becuase that video is a little distorted hard to tell... That's pretty much like my friends sounded that I just helped him pull his engine and replace his spun bearing, except he replaced all of them then dropped his motor back in and that noise was gone. But you really don't know til you get down in the engine and start looking at different things.
Old 04-26-2012, 01:30 PM   #20
MT0911's Avatar
Trader Rating: 0
Yep - it's hard to tell from the video - I tried listening to it without bass and then with bass and the sound is difficult to make out.
The best thing to do is start ruling out possible culprits. First things first, go to your local auto store and buy a mechanics stethoscope:
Listen to any cylinders that sound abnormal from the rest. If you can limit it down to the "problem" area then you'll have less work to do. If all sound the same then I would check the obvious things first on the valvetrain: rockers, pushrods, lifters, alignment, etc.
Read this -
Quote:
FWIW, EVERY cam install I have done using the LS7 lifter with a cam with greater than .600" lift (read smaller base circle) AND stock heads w/GM MLS gaskets has taken 7.425" pushrods for ~.050"-.060" preload. We measure lifter preload on each and every cam install we do. I have never had a lifter failure nor do we end up with the dreaded "sewing machine" noise.
Its very simple, If you change ANY of the following:
valve sizes, valve job, head milling, thinner/thicker head gaskets, decked block, cam with an altered base circle, etc... YOU MUST CHECK FOR PROPER PUSHROD LENGTH.
I have helped countless numbers of individuals with this process over the phone, via email, and PM's. I've posted the process on at least 3 occasions.
Here it is again in a nutshell:
1. Using the EO/IC method, get the lifter to the base circle of the cam.
2. Using a known length pushrod (7.400" is a good start with stock rockers) run the rocker arm bolt down to zero lash. This is easily done with your fingers "wiggling" the rocker, the point at which the "slack" is just gone is zero lash.
3. Set your torque wrench to 22 lb./ft. Tighten the rocker to full torque and count the number of turns it takes to get there. 1 full turn wtih a stock 8mm X 1.25 bolt is ~.047" preload as measured at the pushrod/rocker interface.
4. I normally shoot for 1 1/4 to 1 3/4 turns with stock type lifters like Comp 850's, LS1, LS7 etc.
For an example, if you use a 7.400" pushrod and come up with 3/4 of a turn, you will need at least .025" longer pushrod to get into range. If you end up with 2 1/4 turns, you will need one .025" shorter...
I might not know everything but I will tell you that this method has worked for me year after year cam swap after cam swap. We average 3 cam swaps a week here so you can do the math.
If you are not familiar with the EO/IC method for determining valve events in a 4 stroke engine, its very simple:
For a given cylinder as the Exhaust valve is Opening, the intake lifter will be on the base circle of the cam and lash/preload should be checked for that intake valve.
For a given cylinder as the Intake valve is Closing, the exhaust lifter will be on the base circle of the cam and lash/preload should be checked for that exhaust valve.
THIS METHOD ALWAYS WORKS!!!
I hope this helps someone. I have explained it so many times I think I do it in my sleep!!!
Shane
Try this method with the pushrods and make sure you have the right length. Usually if the sewing machine sound is excessive then you may be running too short of a pushrod. Also make sure all your rockers are centered on the valve stems - if they are a little off they could be clipping it and making a tapping noise. Make sure you see all rockers have a little bit of oil on them and if you have the valve covers off you can lightly press on each rocker/pushrod end and check for collapsed lifters. If one of the lifters compresses that means it needs to be replaced. These are some immediate, easy checks to complete and you can figure out where it's coming from it'll make fixing it easier.
The sound: is it coming from the top end of the motor or the bottom end?
Top End = Valvetrain
Bottom End = Oh no lol
Good luck man!
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
02, bottom, corvette, deep, end, engine, lifters, loud, lq9, meachin, motor, noise, quiet, rebuilt, sowing, ticking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
