5.3 3.80 bore forged pistons
Old 04-27-2012, 11:12 PM
66vert's Avatar
Default 5.3 3.80 bore forged pistons
I'm wanting to rebuild my 5.3 with a minor bore. Can someone recommend some forged pistons 3.80 bore X 3.622 stroke?
Old 04-28-2012, 06:45 AM
KCS
Moderator
KCS's Avatar
What are the plans with the engine? Boost, nitrous, NA?
Old 04-28-2012, 07:51 AM
batboy's Avatar
If you are planning on N/A check these out:
http://www.texas-speed.com/p-741-wis...l-engines.aspx
Old 04-28-2012, 09:27 AM
66vert's Avatar
I was planning on boosting it. Looked at Wiseco, JE/ SRP, Mahle, Summit websites and couldnt find much info. Is there a stock replacement except forged .020 over? Thanks guys.
Old 04-28-2012, 09:57 AM
mark21742's Avatar
You could just bore it out to a 5.7.....an iron block ls1 would handle lots of boost
Old 04-28-2012, 11:49 AM
KCS
Moderator
KCS's Avatar
Wiseco K474M965:
http://www.wiseco.com/Catalogs/Automotive/Chevrolet.pdf
Old 04-28-2012, 03:37 PM
66vert's Avatar
I know this sounds totally old school and they are another company but when I was in high school shop; there was TRW. They were reasonably priced forged slugs. Anything like that?
Old 04-28-2012, 04:22 PM
salemetro's Avatar
Why the desire to bore it? Is is in NEED of one? If your plan is to boost, how much are you going to throw at it?
Old 04-28-2012, 04:48 PM
NemeSS's Avatar
yes. speed pro make a replacement hypereutectic up to .060
for both the 4.8/5.3. they use same compression height and wrist pin.but they are for the pressed pin older version rods.
also there is the dished version (5.3) piston
or flat top (4.8) piston
they have different part no.
i gonna see if i can find em again
Old 04-28-2012, 05:30 PM
66vert's Avatar
That would be awesome of you NemeSS
Old 04-28-2012, 10:05 PM
66vert's Avatar
the motor has 180K miles on it and probably never had some of the plugs change and missed a lot of oil changes so I wanna build a reliable motor. Boost will depend on whether or not I can get a reasonably priced forged crank.
Old 04-28-2012, 11:16 PM
69cutlassrkt's Avatar
Why not save some money and use the stock crank?
https://ls1tech.com/forums/forced-in...k-1200-hp.html
Old 04-29-2012, 12:38 AM
66vert's Avatar
y2khawk has some impressive results with a stock crank. Thats for sure. Makes me think twice about running the stock crank. Thanks for digging up and passing along that thread.
Old 04-29-2012, 02:23 AM
salemetro's Avatar
Exactly. The 5.3 and 4.8 engines can take a pretty good amount of boost with stock rods, pistons, and crank....even more with 317 heads. That's why I asked why you were wanting to bore it. It might not even need a bore. Just freshen it up, widen the ring gap a bit, and throw the air at it.
Old 04-29-2012, 03:47 PM
66vert's Avatar
thanks for the advice and link fellas. I just picked up a set of 853 heads I was gonna try to port myself and use on the motor.
Quick Reply: 5.3 3.80 bore forged pistons
