blown headgasket, cracked block?
so i met a 2011 5.0 today on the interstate and we decided to run from 70, well we got to around 140 and i finally pulled two cars on him. next thing i know, i pull on the interstate and i see white smoke from the tailpipes! i get to work a mile down the road and park it. 00 ss cammed ls1, water everywhere under the car and oil pressure is down dramatically, temperature was about 65 degrees, motor fully warmed up. can someone diagnose the problem?
from what i seen, i didnt see anything up top, and also in wheelchair so a lil bit harder haha. i did notice it was more leaking from the drivers side
man ive been wanting to race a 5.0 for months just havent found one that wants to run! lol ... could be a blown heads gasket, check you coolant level and check your oil if oil is overflowed and watery than very well could be a blown head gasket
im thinking its a blown head gasket, the coolant level is very low cause most of it is below the car and i pulled pretty good on him. i thought they were a bit quicker than what i seen
My apologize if I came off rude, it was not my intention.
What did your oil pressure drop to and when did you notice it drop? What is the oil level?
Check the oil and see if it feels or appears thin. It might have a "milky" appearance but it might be too soon to appear obvious.
When you say coolant is leaking from the Driver's side, is it front or back of the engine bay?
We can try to narrow this down.
No No2 or anything, cam only?
its alright haha i dont know any other guys in wheelchairs that drive a 450 hp camaro lol havent checked the oil yet and looks near the back. noticed it drop when i came to a stop.. cam, ported ls1 intake, ported 241 heads, catch can, bolt ons, free mods, tuned, built 4l60e with 3800 stall, 10 bolt. n02 is out currently dropped to 40
At the driver's rear, the only thing that comes to mind would be headgasket or coolant crossover tube going into the head. The coolant crossover tube would be at the rear driver's side corner of the intake.
No other abnormal sounds though?
When it cools down, start it and see where your oil pressure is at.
if you think its a blown head gasket dont start it, if water is in a cylinder and you start it you run the risk of hydro lock which will break something like a rod, better off getting it towed and checked out
my exhaust is ran for 1 7/8 primaries throu an x pipe to duals, i couldnt hear anything differently. i get off in 40 minutes and ill go check the tube and see if i cant get under the car a bit and see the leak sight
blu99ta, where in MO are you located?
Okay so I checked real good and leaking from water pump and normal oil pressure now.. Also threw a code, low input knock sensor.. So new diagnosis? The power just don't feel like its all there.. Still 340 horse but losing round 100 ? Lifter?
i bought the sensor already and i need to buy the harness also. and i guess im going to take the water pump off and see if its a gasket or possible crack.
Water pump could be leaking out of the impeller shaft, iv had this before, did a coolant change before i went on holidays a couple off years ago and pulled up to a place came back to the car and noticed a coolant trail from the front, not fun with it being on holidays and a weekend but still drivable, might be worth just putting a new one on if pulling it off with the new gaskets.
Sounds like a nice car too.
the leak is VERY minor, still driveable but it will be parked till i replace the knock sensors and harnesses. might as well paint the intake while its off for the summer car shows
thanks for the part number blu99ta
thank you ausls1
thank you ausls1
