5.3 in a 98-02 f-body?
Old 04-28-2012, 08:23 PM
deerslayinrednek's Avatar
Default 5.3 in a 98-02 f-body?
Whats needed to put a 5.3 in a 99 camaro that has an engine thats shot?.......The guy is looking to do it on the cheap......What parts/sensors won't swap over?........If there is a write-up somewhere I couldn't find it......Thanks
Old 04-28-2012, 08:47 PM
nascarnate326's Avatar
what motor does it currently have?
Almost everything LS1 based will swap over.
If its a 3800...different story.
Old 04-28-2012, 09:14 PM
Swaie's Avatar
I'm thinking its a straight swap, just use the ls1 intake minifold, from what I know, which aint much, the blocks are the same just the rotating assembly is different...if you keep it stock I think it will be slower, so do a heads and cam swap before if power is an issue...
Old 04-28-2012, 10:29 PM
01ssreda4's Avatar
Its a direct swap as long as you stay Gen3 to Gen3.
Old 04-29-2012, 11:54 AM
it's a 5.7
what yr 5.3's are gen 3's?
Old 04-29-2012, 04:57 PM
01ssreda4's Avatar
Have to read up on specific year model changes and be able to identify the visual differences.
Old 04-29-2012, 06:25 PM
badazz81z28's Avatar
I would look for a decent LS1 replacement short block. Why go smaller???
Old 04-29-2012, 06:33 PM
gt35built's Avatar
because you can get 3-4 5.3 pull outs for the price of 1 5.7.
Old 04-29-2012, 06:54 PM
Yea for good reason too. 5.3s can be built up, but thats not cheap.
I guess if the mission is to just get you back on the road....Performance will be a disapointment as power is lower with a heavier foundation.
Old 04-29-2012, 07:16 PM
Luke1834's Avatar
i got my 5.3 bored over to 3.903 with a stock ls1 crank with forged callies rods and forged weisco pistons runs like a champ i bought a tubular k member to compensate for the iron block weight, planning on spraying 200 shot of nitrous both ls1 aluminum blocks i have had have cracked and i paid 100 dollars for my 5.3the only thing i had to do is drill and tap a hole to mount the ls1 alternator
Old 04-29-2012, 07:54 PM
Good to know
Also just wanted to say I'm not looking to do this for myself, it's for someone who wants the car back on the road quick and cheap.....He claims he wants to build the LS1 when the funds are more available
Old 01-27-2017, 03:01 AM
Damon Kelehan's Avatar
Default pcm
Which pcm and engine harness should I use for the lm7 going into a 99 T/A ws6 I have both harnesses and pcm
Old 01-27-2017, 05:56 AM
Restricted User
JoeNova's Avatar
You could use the 5.7 PCM and have it reflashed for the 5.3, or use the 5.3 PCM and have it reflashed to work with the VATS for the WS6.
Or you could just use the 5.7 PCM as-is.
One thing they forgot to mention 5 years ago when this was posted, if its an iron 5.3 you'll have to redrill the mounting point for the alternator bracket. The aluminum 5.3s are already drilled there.
Quick Reply: 5.3 in a 98-02 f-body?
