LQ4/LQ9 build
Old 04-29-2012, 01:33 AM
Banned Scammer
BashamWS6's Avatar
Default LQ4/LQ9 build
So heres what im considering
Im considering selling my two ls1s to fund my lq4/9 build.
Im thinking lq4/9 with a (i think Lingenfelter GT-7) )boost cam and cncd 317 heads. Forged internals, stock crank. Maybe z06 cam for cheap, high pressure oil and water pump, swap all the other accessories and ls6 intake off my ls1, and finish with 60# injectors and a 255 walbro with hotwire kit.
Will be accompanied by a d1sc fmic, tick level 3 tranny, and mwc 9".
Suggestions? help? thoughts? concerns?
Old 04-29-2012, 05:30 PM
Banned Scammer
BashamWS6's Avatar
any one?
Old 04-29-2012, 06:07 PM
Banned Scammer
BashamWS6's Avatar
any body?
Old 04-29-2012, 10:31 PM
squirlNUTZ's Avatar
Sounds like a good idea to me.
Old 04-29-2012, 10:40 PM
mark21742's Avatar
I like it
Old 04-30-2012, 01:48 AM
Banned Scammer
BashamWS6's Avatar
Nice. thanks
well, a few questions.
what about a timing chain? ls2 or double roller? and what about under drive pulley?
what valve springs should i go with?
what about lifters? ls7 be good?
how dished should the pistons be?
Old 04-30-2012, 06:52 AM
mark21742's Avatar
You will need to do a little grinding inside the timing cover, but I'd go double roller and Melling 10296 oil pump......this is the setup I'm running. Just bolt everything in and put grease on the oil pump bolts/ face, then slide the timing cover on and push against the pump.....pull back off and grind on the inside of the cover where ever the grease sticks to it till it fits good and flush with the block.....THEN put the gasket on and that will give you plenty of clearance.
What are the cam specs? If its under .600" you can probably use a good single beehive spring like the comp 918, or PAC 1218.
I run the ls7 lifters with no issue on a .624 lift and spin my 408 to 8,000 rpms.
As for pistons, I'd look at the whole chamber/ compression....set it ip to run a .040" mls gasket, is take the time to polish the head chamber and cc it, then after that get a fish size that puts you right around 8.75-9.0:1 compression depending on how much boost you plan on running.....if you come up with a figure with a flat top piston working to get your compression I'd mill dome off the heads just so you can run an 8-12cc dished piston so the main combustion forces are more on the center of it and not out towards the ring lands.
While your at it replace the old lifters trays with new ones too.
Old 04-30-2012, 09:46 AM
Banned Scammer
BashamWS6's Avatar
Yeah i want a 6.0 but my shop guy just told me that the ls1 would be just as good for a d1sc build.
I mean... What do you guys think?
Quick Reply: LQ4/LQ9 build
