5.3 iron block 317 6.0 heads....pushrods
Putting this together to replace my ls1...I have stock mls head gaskets..ls1 lifters and pushrods. And I'll be using the stock ls1 cam Can I use the ls1 pushrods or not?
Cool, my 317 heads with a 3.905 bore is around 9.1 : 1 compression and I wouldn't go any lower for street driving.
To your original Q, I would go with a hardened push rods and a good spring, might even want to go double valve spring. Boost will eat up a weak valve train.
