5.3 heads milled .030 what size cams are you runnning and what dyno numbers
To those peoplle who have 5.3 heads milled .030 what size cams are you runnning and what dyno numbers are you putting down?
I have some MTI S2 5.3's cut .030 and I got a 232/237 591/598 114 +4 without have to touch the pistons. Motor isnt in the car yet but I will post the numbers if they are good.
Originally Posted by destroyerSS
WOW, that has to be very close!!! Jay @ absolute is doing 5.3 stage 2.5's with my TSP 231/237 598/595 unmilled w/2.055 & 1.575 valves and i was told to use the thicker head gaskets because with the stock gaskets the P/V clearance was .065 and that is considered close and with the thicker gaskets i'll be around .085 which is safe.BTW what size valve's did they use for your heads since that will also play a big part in P/V clearance anyway good luck with your new set up
