How do you remove the knock sensor on a 2000 ls1? - LS1TECH
Old 05-20-2016, 12:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
Print Wikipost
Thread Tools Search this Thread
Old 05-03-2012, 05:33 PM   #1
Default How do you remove the knock sensor on a 2000 ls1?
Intake is pulled off, how do I get the knock sensor's out?
703 CAMAROSS is offline   Reply With Quote
Old 05-03-2012, 05:39 PM   #2
22mm socket I think to remove the sensor.
To remove the connector use light pressure with a pair of pliers.
BOXCHEV is offline   Reply With Quote
Old 05-03-2012, 05:43 PM   #3
Just pull up?
Old 05-03-2012, 06:13 PM   #4
yeah
Grip it from the lil tabs on the side with the pliers, lil pressure on them when you squeeze the pliers and just pull up.
Old 05-04-2012, 07:09 AM   #5
I got them out thanks.
Old 05-04-2012, 07:12 AM   #6
Don't be surprised if you throw a code for Knock sensors after the change out. I had to pull the intake twice - once for the sensors and again for the harness itself.
z28clark is offline   Reply With Quote
Old 05-04-2012, 09:17 AM   #7
Grimes's Avatar
yeah, if you change the sensors/sensor connectors out, it's a good idea to put RTV silicone all around the black rubber plug so that water cannot collect inside
Grimes is offline   Reply With Quote
Old 05-04-2012, 09:42 AM   #8
PowellSixO's Avatar
Quote:
LOL. I learned this the hard way too. Helped my buddy do his knock sensors and had to do it twice because of the harness. Saved me time with my truck though.
Also + 1 on the silicone.
PowellSixO is offline   Reply With Quote
Old 05-04-2012, 08:20 PM   #9
Why would it throw a code if you put new ones in?
Old 05-04-2012, 09:59 PM   #10
If you end up needing a harness I have one I don't need.
McLeod is offline   Reply With Quote
Old 05-05-2012, 06:17 AM   #11
Quote:
My best guess is from heat cycles, the plastic connectors and wiring gets brittle and not give accurate readings that the sensor is actually producing.
Old 05-08-2012, 10:43 PM   #12
Quote:
sorry for the hijack but I need the harness I just bought a motor for my chevelle swap and it was missing it. What do the sensors do anyways??
Thanks
mdrn69velle is offline   Reply With Quote
Old 05-08-2012, 10:54 PM   #13
nvm found what they are for. timing right?
Old 05-09-2012, 07:41 AM   #14
Technical Facepalm
crainholio's Avatar
Quote:
The knock sensors are basically microphones that "hear" spark knock and input that data to the PCM so it can retard ignition timing.
The LS PCMs have a slick function called the Adaptive Spark Scalar that makes the change more persistent and global, knocking down the entire advance curve in percentages. It does a better job of protecting the engine vs. older systems that simply react to knock when it happens.
crainholio is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
can you relocate the knock sensors billymgb1000 LT1-LT4 Modifications 1 11-01-2013 08:18 PM
How do you delete Knock sensors? SmaknaSS PCM Diagnostics & Tuning 11 01-12-2013 12:10 AM
Diagnosing Knock Retard Z28Camaro30Ann LT1-LT4 Modifications 17 08-13-2012 10:03 PM
Knock sensor removal Mohammed LT1-LT4 Modifications 6 03-24-2012 07:52 PM
LS2 f-body and Kooks stroker headers= no knock sensors? Jimmy P Generation IV External Engine 20 02-03-2009 10:48 PM
Tags
2000, adaptive, camaro, change, changing, disconnect, knock, ls1, ls1tech, removing, scalar, sensor, sensors, spark, ss
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
