COMP or SLP double roller timing sets in a ls6 ?
will a double roller timing set like the comp adjustable , or a slp double roller fit behind the factory timing cover ? will it interfere with the oil pump or water pump ?
i just want to know if its a simple swap i dont want to move my oil pump around or shim it ect.. ? is it possible or should i just go with a single roller after market set with sprockets?
thanks for the help
Junior
thanks for the help
Junior
I just installed the SLP chain and it does fit behind the cover, but the only reason is because I have the SLP pump too. SLP grinded a small area in the back of the pump to clear the chain. That means I didnt have to use the spacer that come with the chain. From my observation, no matter what double chain you get, you will have to either grind the cover or the pump. I suggest just getting the SLP chain/pump combo.
well its not my ride its my bros 04 z,
i dnt think hes getting a pump, just a chain set,,
what single roller do you recommend ??? i see texas speed shows a comp single roller ??
so any single roller should not be a problem right
The LS2 replacement chain is the popular choice among the folks here.
who sells it for 40,,? is that just the chain or is it with the sprockets,, ?
if its just the chain should he just go with a c5 r chain from katech or should he get a set with the sprockets?
ill tell him about tht too, the reason being he had a lifter go bad on him so hess getting another cam , lifters, ect. so thts why hes getting the new chain
