Hey where did that carb washer go?
Literally went to put the carb on top of the motor to finish it tonight and one of the stud washers is missing. I can't find it any where. So guess what I get to do? I get to take this thing back down to a short block and make sure its not in the intake or down in a piston.
I think I am done for the night. Gotta have a better attitude before I break down all my work. I had everything taped off but you just know it fell in the intake when I pulled the carb earlier tonight. If I don't tear it down it will be in the piston. If I do I probably want find anything. But you gotta do what you gotta do.
Kevin
Kevin
Pop the intake off so you can look down the runners. Get a pen magnet and you can see if its down there. With the right size one you can also fit it in the spark plug holes too. Not sure what size washer it is, but you should be able to go all around the top of the piston and in the chamber. Hope you find it.
Thanks...
Well the good news is that I had not installed the rockers since I am having the machine shop press in new Comp trunions. So that meant all of the valves are closed. I pulled the intake and looked down all the runners and no washer sitting on the top of the valves. I used a extendable pen magnet as suggested and found nothing with it either. I could see pretty good into the head so visual and magnetic check yielded no washer. Thankfully it was not stainless so the magnet is a good check. I tested on one of the other washers just to make sure.
I do have some other questions though. I installed the heads with the FelPro MLS gaskets and ARP head bolts. Its my understanding the head bolts from ARP are reusable unlike the stockers. Are the gaskets reusable after they have been torqued down?
Thanks for all the great feedback guys.
K
K
Kevin
Kevin
K
K
