Fast 102 Fuel Rails leaking! PICS Inside!
k so i put on my fast 102 today and i also have the billet fuel rails and i got everything tightend up and im leaking fuel from this little hole from th AN fitting! wtf! am i missing somthing or did i do somthing wrong? i also put some tread seal tape and that still didnt work. can somone help! i couldnt get pics from the rear, but heres the front.
the hole is suppose to be there, idn y i think its stupid that they did that. anyone else that running the same set-up???
1. You DO NOT use pipe dope or tape, on an AN fitting.
2. That "hole" is a lock pin to lock the fitting together.
3. It appears that you have a cheapo crimped hose fitting that's in a bind. Leaving that braided line lying on the surrounding parts will chew them up.
4. Can't tell from the first pic, but it looks like the fitting is screwed onto the rail fitting so far that it's bottomed out. Y/n?? WTF did you use to tighten it, a pipe wrench??
4. What is that squeezed out between the rail and the fitting? An o'ring?
op just call fast and tell them its leaking from the pin hole they'll probably send you another one, do not use pipe sealant or tape for the an fittings, with my fast fuel rail where the fuel line hooks up to the rail i had to really tighten the **** out of it to stop leaking from the threads
k well i took off my fuel rails today, and yes it was vise grips...... yesssss..... i knooooooo....stupid thing to do. but i needed my car running asap cause its my DD and a friend of mine had my crescent wrenchs, so finally retightend everything back up, so far so good no leaks. i sware this always happends to me when somthing goes so smooth n perfect SOMTHING ALWAYS HAPPENDS! FML. thxs everyone.
