does removing rocker bolt (bosses) on stock ls1 heads give greater cfm?
Old 05-21-2012, 02:21 PM
LSXFEIN's Avatar
Exclamation does removing rocker bolt (bosses) on stock ls1 heads give greater cfm?
hey everyone im getting my heads port & polished and the shop doing it doesnt want to remove the rocker bolt bosses because they say it wont give much advantage?? or it doesnt make a big difference is that true?
Old 05-21-2012, 02:41 PM
LSXFEIN's Avatar
Default bump
bump.....
Old 05-21-2012, 04:32 PM
LSXFEIN's Avatar
anyone?
Old 05-21-2012, 05:40 PM
DONAIMIAN's Avatar
What do you mean remove?
Old 05-21-2012, 06:07 PM
gtotoocool1's Avatar
i know some will disagree,but only when you start to move some big air does it really help.biggest restrictions are going to be just below the valve/bowl area and then the guide boss.just go with what the shop recommends..
Old 05-21-2012, 07:12 PM
LSXFEIN's Avatar
the hump inside the intake runner for the rocker bolt
LSXFEIN's Avatar
right on thanks
Old 05-21-2012, 07:13 PM
TVWilkes's Avatar
Every major head porter removes that bump. It will not hurt a thing.
Old 05-21-2012, 09:52 PM
LSXFEIN's Avatar
Right on i told him they gotta do it!
Old 05-21-2012, 11:40 PM
PREDATOR-Z's Avatar
Sounds like your shop doesn't know much about LS heads.
Will it make a big difference? NO
But that is the trick where attention to details makes a difference here and there and eventually (looking at the bigger picture) the difference between an average porter and a specialized professional.
Old 05-22-2012, 06:04 PM
LSXFEIN's Avatar
Exclamation Exactly
yeah i think i made a mistake, he cant find the valve guides either he gave me some dimensions to look up, i honestly can find them either. theyre outside diameter is .502 ands inside is .335 and legnth is 1.980????
Old 05-22-2012, 10:04 PM
A.R. Shale Targa's Avatar
I knocked mine out (241s) and only cartridge rolled the bowls yet gained 12 cfm with the factory GM valvejob.......so yes it does help at least a few......
perhaps 5-7 cfm.
Old 05-22-2012, 11:50 PM
Paul57's Avatar
I would seriously think about telling the shop that you changed your mind and don't want them ported at all. They obviously aren't that familar with LS heads . It could be a big mistake to move forward!!! You are much better off saving up for some CNC work from a reliable shop that knows LS stuff.
Old 05-23-2012, 12:16 AM
LSXFEIN's Avatar
Unhappy
yes i wish i could but he started them already ...
LSXFEIN's Avatar
right on
perhaps 5-7 cfm.
Old 05-24-2012, 04:52 PM
LSXFEIN's Avatar
its taking this shop over a month to do my heads....
Quick Reply: does removing rocker bolt (bosses) on stock ls1 heads give greater cfm?
