Aftermarket oil pan options?
Looking for something other than stock, a direct replacement. Prefer something I can weld a return drain on, for a turbo setup. Going on an 01 f body.
That's MISTER MODERATOR
^Also agreed! Get a remote filter mount with the 13/16"-16 spin-on filter thread and you'll be able to use the original small block/big block bigger sized quart filter. Keep all your lines -10 sized for less restriction. The Aeroquip AQP socketless hose is light and doesn't need expensive fittings.
